Home > Technical (L322) > Code Reader/tow bar electrics
Seancod
I have a 2011 Vogue and want to fit a tow bar. I understand that the electrics will need coding. What does that mean exactly, I assume this can be done by a code reader. This brings me to the point, what is the best code reader you guys use and will it code the tow bar electrics. Thanks in advance.
Post #546604 9th Mar 2020 7:31pm
DrRob
No coding needed on a 2011. Buy the genuine 13pin kit and plug it in. Make sure the cross member grommet is fitted correctly. Use silicon spray. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #546618 9th Mar 2020 8:01pm
Seancod
Thanks for that, I presume the tow bar kit I looked at has an after market loom, that’s why it needs coding.
Post #546622 9th Mar 2020 8:24pm
DrRob
Maybe, not sure. I just got a genuine one from site sponsor Duckworths. Plugged it in. Job done.
I use it only for battery top up charging via an adaptor lead for my Ctek charger
https://www.disco4.com/shop/tow-electrics-...c-p45.html
Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #546625 9th Mar 2020 8:53pm
Arbuckle
United Kingdom 2012 Range Rover Westminster 4.4 V8 Fuji White
Socket works a treat for topping up battery from charger as I do not use L322 often enough.
I used the factory electrics when fitting the towbar.
With conventional bulbs on the trailer, the message to select the type of trailer has been connected, caravan, car transporter etc appears.
Unfortunately, LEDs illuminate fine - BUT - do not trigger the interactive message, nor the indicator warning icon.
Does anyone know which lights the ecu looks for to trigger the message (side, stop, indicators)? I guess it could be any or all of them. Forty years of progress. 1972-2012
Post #546640 9th Mar 2020 11:16pm
dazza1983
Sorry to hi jack a thread, but if i wanted to replace my existing towing electrics is this easy to do?
I worry about the grommet and water ingress? Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #546788 11th Mar 2020 2:13pm
Arbuckle
2012 Westminster.
I removed the rear bumper first as I was fitting a towbar as well. Not difficult but access to the left hand inside nuts was limited. It was only when refitting that I realised the wiring loom could be lifted clear - Dohh!
Wiring plugs in easy inside and bolts to towbar the other. Feed through grommet had good access.
Not sure if the grommet could be done with the bumper in place though ! Would need to take a look first.
Cheers. Forty years of progress. 1972-2012
Post #546827 11th Mar 2020 6:54pm
DrRob
Tow electrics can all be fitted with bumper in place. The trickiest bit is getting the grommet to seat properly. Use silicone spray to ease fitting. Small hands help Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #546836 11th Mar 2020 8:12pm
Seancod
What code readers do you guys have
Post #546860 11th Mar 2020 10:23pm
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
IID Tool best one to have for a RR
Post #546865 11th Mar 2020 10:54pm
