Home > Maintenance & Mods (L405) > Anyone replaced the cooling radiator?
archermav
United Kingdom 2016 Range Rover Autobiography SDV8 Corris Grey
As above really gents. Noticed a small coolant loss over recent months (I only do about 3000 miles a year). Went in for it's MOT yesterday. Was advised that it appears radiator maybe on the way out as there was a small amount of coolant sitting on the bottom of it, the outside of it that is Whistle
The actual radiator doesn't seem hugely expensive, so wondering if it's something easy'ish to sort.
I've checked WIKI, but no good.
Cheers
Post #546697 10th Mar 2020 4:17pm
Not the end of the world a job sir... You can unbolt the front easily enough... From memory the slam panel pulls forward giving enough room without the need to remove it Thumbs Up
Post #546746 10th Mar 2020 11:36pm
archermav
Good to know mate, thanks very much. Thumbs Up
Post #546825 11th Mar 2020 6:53pm
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
I’ve just changed the aircon condenser and it’s nearly the same job. I am meaning to write it up for others.
Essentially the process is grille off, bumper off, slam panel off (3 bolts either side at the top and 2 either side at the bottom plus unplug a couple of things like horns and bonnet switches) and a couple of screws holing the inter coolers and it comes off really easily. Then front crash bar off 4 bolts either side and some plastic parts and you have access to the 3 radiators - oil cooler, aircon and main radiator.
I never got involved with the radiator connectors so can’t help you there. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #546864 11th Mar 2020 10:50pm
archermav
Thumbs Up Thanks very much, appreciate it.
Post #546891 12th Mar 2020 10:41am
