Home > Technical (L322) > Whumf whumpf noise solved at last
Sandyt
It was the front prop which was done yesterday so now all good but on the way replaced front and rear diffs had the rear prop redressed and all the wheel bearing replaced plus rear subframe bushes (2nd lot) front arms (lost count) new front hub carriers but have to say drives beautifully
Post #547043 13th Mar 2020 10:16pm
DrRob
Good to get those irritating noises sorted Thumbs Up
Who did it for you? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #547061 14th Mar 2020 8:34am
Sandyt
I do some myself but have a friend who has a garage so have access to ramps and advice/help took the front prop off and it was well worn when I had the exhaust off to do the rear prop I replaced the gearbox mounting it was ok actually but it was 12 years old and the car is on 192k so it does no harm
Post #547075 14th Mar 2020 10:02am
TomV8
United Kingdom 2004 Range Rover Vogue 4.4 V8 Bonatti Grey
Congratulations SandyT on getting to the bottom of it. I’m impressed by your determination and persistence šŸ‘ 2004 L322 4.4 V8 Vogue Bonatti Grey
(205,500 miles and counting.......)
Post #547077 14th Mar 2020 10:21am
Sandyt
To be fair it is easy when the car is old and has lots of miles because you dont get frustrated replacing bits as even if they were not the culprit they are probably all well worn and have given good service
Post #547078 14th Mar 2020 10:27am
