Home > Technical (L322) > 3.6 lower hose leak
Rich86
United Kingdom 2009 Range Rover Vogue TDV8 Nara Bronze
3.6 lower hose leak
Morning,
I’m replacing the two top turbo inter cooler hoses which are clearly marked with part codes so nice and easy. What’s proving to be difficult is identifying the lower house so that I can order from Duckworths so if anyone has done this before a part code would be great please.
Also would anyone recommend using silicone hoses as opposed to standard OEM parts?
Cheers in advance. 2009 Vogue TDV8 Nara Bronze
2002 Vogue V8 Zambezi Silver
1986 90 Pick up Deep Bronze Green
1978 Series III SWB Deep Bronze Green
Post #547200 15th Mar 2020 10:01am
Laurie915
Australia 2010 Range Rover Autobiography TDV8 Buckingham Blue
Rich
The lower hose in silicon usually comes in a hose kit I thought; could be wrong ! Depending on price I'd use silicon, it always helps when you go to sell that you can show that you replaced the originals with silicon hoses. Peace of mind for the new buyer;
https://allbrit.de/epc.cfm?PAGE=3031210-T3...SPRACHE=EN
Laurie
Post #547203 15th Mar 2020 10:47am
The original LR houses come individually.
I would just tell Duckworths what you want they should be able to find it on their parts catalogue. I used to ask Dan all the time for numbers. There is nothing that can't be fixed with a hammer😜😜
Post #547207 15th Mar 2020 11:30am
Rich86
Thanks guys. I think Dan has moved on now and the one I deal with at Duckworths is now Rob.
I’ve got Maltings Off Road as a potential to buy silicone if that’s the way I go. Has anyone used these guys before? They’re based in Doncaster. 2009 Vogue TDV8 Nara Bronze
Post #547209 15th Mar 2020 11:39am
DavidS
Spain 2007 Range Rover Vogue SE TDV8 Java Black
I purchased a full 6 hose set in silicone from LR Centre Ltd, including post to Spain, £105
Post #547307 16th Mar 2020 11:39am
