![]() | Home > Technical (L405) > Front air suspension re-levelling after starting |
dennij Member Since: 24 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
Where you park is it level or does it dip down slightly? If it has a slight dip the suspension maybe finding it's level when you start up, you could park the other way round and see if the front still lifts. Also, not very scientific I know but you could measure the gap between tyre and wheel arch when you park and check again next time you go to the car and see if it's dropped. |
Jase71 Member Since: 13 Apr 2016 Location: Mona Vale Posts: 492 ![]() ![]() ![]() |
I think the surfaces are pretty level and would not have thought the amount of height change would be needed to correct. Most of the Time the car is Set to auto access height but if I turn it off and leave the car at normal height, you see the front height minor correction when starting. 2017 Range Rover Vogue V6 Diesel
Something I don’t notice when the car is in auto access height 2017 Range Rover Vogue V6 Diesel
mine has occasionally done this when parked on an uneven surface...i reckon its self leveling.. ... - .- -.
thanks Stan. I think I'll turn on auto access height again and then I won't need to worry |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1419 ![]() ![]() ![]() |
Rising a bit on start-up is normal as far as I am concerned, I've never worried about it. I asked for auto access height to be turned off as I don't need it and it's just adding to the "work" the car has to do so it might wear out sooner (?). Only Range Rovers since 1988 |
you say that you 'asked' for the auto access height to be turned off, did you know that its selectable in the drivers menu... ... - .- -.
You are quite right, what I did was to ask the dealer to turn it off at handover as I knew it would default to that and I didn't want to have to work out how to switch it off. Only Range Rovers since 1988 |
Crasher242 Member Since: 07 Mar 2019 Location: Warwickshire Posts: 140 ![]() ![]() ![]() |
Mine does the same - and mainly happens at home as our widened driveway has a distinct slope and dip |
