Home > Technical (L405) > Heated Wheel not working
Spooky
United Kingdom 2014 Range Rover Autobiography 5.0 SC V8 Corris Grey
As above - my heated steering wheel ... doesn't! Rolling Eyes
I've checked the fuses, and they're good. Anyone else had this issue and, if so, where should I start looking? Regards,
Mick
'Bertha' - 2014 SDV8 Autobigraphy
'Vincent' - 2010 TdV8 Vogue SE
- 'Molly' - 2005 HSE Auto
'Dixie' - 2000 D2 Td5 ES
Post #547419 17th Mar 2020 9:50am
Baltic Blue
Are the relays labled,?
It might be possible to try swapping it with a similar relay for another function.?
Post #547427 17th Mar 2020 11:11am
Does the button light up when pressed?
Post #547446 17th Mar 2020 2:03pm
Spooky
No Craig, it doesn't.
My current thoughts are either the module (LR036111), or the wheel itself. Regards,
Mick
Post #547462 17th Mar 2020 4:46pm
LT
I had random moments when my heated wheel, seats and windscreen wouldn't work. I assumed it was the battery but that checked out okay. Turned out it was software glitch and sorted by an update. (MY2017 SDV8)
Post #547530 18th Mar 2020 7:17pm
Spooky
Cheers for your reply - all the other bits you mention work just fine. Regards,
Mick
Post #547748 20th Mar 2020 6:51pm
