Home > Maintenance & Mods (L405) > Facelift light stays on even when locked
RRJoshA
Hi chaps, I've got the 19 lights on (aftermarket) and they work great but just noticed tonight that the reverse light is on very dim. Any ideas?
Post #547639 19th Mar 2020 9:12pm
are you talking about the rear lights?
if so , i suspect the wiring hasnt been converted properly, thats unless you have the conversion adaptor cables then it could be the light units themselves. ... - .- -.
Post #547641 19th Mar 2020 9:47pm
RRJoshA
They came “plug & play” so no adapter was used. Cars fully shut down and locked but the right side rear has a very faint white light on
Post #547645 19th Mar 2020 10:12pm
you're probably aware that the 2018-19 lights have different wiring to the 2013-2017 lights so either a conversion adaptor cable is used or the 2018-19 light wiring is re-pinned ..
if yours came plug'n'play maybe the re-pinning was done incorrectly?
check the plugs and make sure the pins arent bent.. ... - .- -.
Post #547647 19th Mar 2020 10:19pm
RRJoshA
Post #547947 22nd Mar 2020 7:21pm
...and?
have you done the sbove? ... - .- -.
Post #547953 22nd Mar 2020 8:16pm
RRJoshA
I realised i hadn't posted a picture. And no not yet with the current circumstances going on it doesn't seem to drain my battery so i thought id wait and take it to a garage in due course
Post #547955 22nd Mar 2020 8:51pm
