Home > Technical (L322) > TD V8 4.4 am I missing a pipe from here ?
klf400
Ok guys have a look at this, front right hand side of TDV8 4.4 this valve/sensor appears to have a pipe missing from it or does it take in air here or vent off
 1990 3.5 v8 defender
2000 4.6 v8 30th anniversary prins lpg
2004 4.4 v8 vogue prins lpg
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #547672 20th Mar 2020 7:01am
GraemeS
Australia
Its definitely a missing hose. It could be the solenoid for the inlet isolation valve for the secondary turbo which is located directly below but the valve not operating would cause various air-flow faults so probably not for that valve. I can have a look at mine in a while.
Post #547683 20th Mar 2020 8:46am
GraemeS
Australia
Looking at the parts diagram the missing pipe appears to be the one going to the turbo isolation valve, part number LR022879 - pipe, vacuum control to turbo valve. I'll have a look at mine within the hour.
Post #547684 20th Mar 2020 8:53am
GraemeS
Australia
Yes, it is what I thought. The pipe runs upwards a little before jumping forwards to then run down the side of the radiator to the turbo isolation valve. There should be several faults for inlet air pressure discrepancy etc.
Post #547692 20th Mar 2020 10:05am
GraemeS
Australia
Thanks Johnboy. I was able to compare the picture with the workshop manual accessory belt diagram to get my bearings then fortunate that the solenoid was visible. If it had been anywhere else on the engine I probably would have been lost.
Post #547696 20th Mar 2020 10:38am
GGDR
Nice one Graham
klf400 you must have your radiator off ?
Possibly front of car too?
. Cheers, Greg
Post #547698 20th Mar 2020 10:47am
klf400
Cheers guys for your help this has clarified the issue thank you very much, indeed I do have the radiator of at the moment I needed to change the alternator , and a few more things as she was a cat N salvage , damage Was limited to bumper and car ash bar so easy repair ,not had time to put it back together until now This is what she looks like at the moment
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #547699 20th Mar 2020 11:02am
klf400
I must of pulled the pipe of when I stripped it down ( that’s the trouble leaving it to long you tend to forget) 🤣 the fan was a pig to undo hellish tight 1990 3.5 v8 defender
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #547700 20th Mar 2020 11:06am
GGDR
since access is so good you might want to think about the NS exhaust manifold sensor which usually cause an error code. Search P040D-00 (2F)
also turbo drain mod?
. Cheers, Greg
Post #547703 20th Mar 2020 11:21am
klf400
Ok will check this out , I did read a brief note about the turbo drain mod which appears to be a pig of a job🤔 1990 3.5 v8 defender
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #547704 20th Mar 2020 11:24am
dingg1
Change the water pump while you're in there
Post #547707 20th Mar 2020 12:00pm
And while you are there to the tensioner and pulleys on the drive belts and the belts....sooooo much easier now. There is nothing that can't be fixed with a hammer😜😜
Post #547810 21st Mar 2020 9:13am
klf400
Yes everything is much easier to get to at the moment , gonna check out all the above mentioned 👍 1990 3.5 v8 defender
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #547842 21st Mar 2020 4:48pm
klf400
the exhaust manifold sensor you mentioned is this the egr temperature sensor? 1990 3.5 v8 defender
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #547892 22nd Mar 2020 8:33am
How many miles are on the engine?
Semi common failure on the alternator. Which is so tempting to say to change as it is just sitting there, nice and ready to take out and swap!! It’s probably fine, but there’s no way to tell when it’s about to fail and it’s a fairly pinchy job to do normally! There is nothing that can't be fixed with a hammer😜😜
Post #547893 22nd Mar 2020 8:49am
