Home > Technical (L322) > Air Suspension Issue
JNC
United Kingdom 2011 Range Rover Vogue SE TDV8 Nara Bronze
Suddenly developed a strange issue with my 2004 4.4 L322.
Driving the a few days ago and air susp fault displayed on dash.
Next day after a short drive the rear droopped fully followed by the front.
Fault code comes up as
18 - Supply, high pressure drain valve - short circuit to positive
75 - unknown fault code.
Diag tool I was using only lists air susp features under E53 section. So codes are BMW.
It is now fully deflated.
I can use tool to raise, compressor starts but never lifts.
Accumulator pressure is around 1 bar. I can deflate and set to inflate. That all seems to work correctly.
Confused Confused
Post #547373 16th Mar 2020 9:33pm
JNC
Spent a while more on this.
I have changed the valve block.
I have also swapped for an X5 compressor (used). Seems to have good pressure.
However, still the same symptoms.
Accumulator doesn’t seem to ever get above around 1.7 bar.
Anyone experienced the accumulator sensor failing?
Post #547878 22nd Mar 2020 12:28am
See here for some ideas....
https://www.fullfatrr.com/forum/post542379.html#542379
You probably have a leak (in an airbag) somewhere, or a dodgy height sensor
Get codes read with proper diagnostics .
Post #547879 22nd Mar 2020 12:39am
JNC
Would I be right in assuming the valve directs air to fill the accumulator. Therefore if an airbag had a leak it wouldn’t show until the vehicle tried to raise?
Post #547881 22nd Mar 2020 1:03am
