![]() | Home > Maintenance & Mods (L322) > How to remove a scratch? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35691 ![]() ![]() |
you could use jewellers rouge or branded glass polish from t-cut for instance but whatever you do use you run the risk of making that part of the windscreen more 'shiner' than the rest..i would have a word with your local windscreen supplier first and get their advice.. ... - .- -.
nick h Member Since: 26 Jan 2011 Location: notts Posts: 782 ![]() ![]() |
as Stan says - a branded glass cleaner but with a rotary polisher (made a similar post minutes ago to Dan |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 ![]() ![]() |
I'll take a trip to the local windscreen crowd then and see what they have to say. Thanks for the advice. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
best of luck if its the monkeys at Autoglass ![]() they replaced the windscreen of the GC and managed to gouge a 'back to bare metal' groove in the bodywork - actually done by the manager himself! |
Hope this is not too off topic but anybody got any tips for a bodywork scratch I have in the Black D3. Its too deep to polish out but to small (2 inches) to really warrant respraying the rear quarter panel. Any ideas? |
Touch it in with paint then cut back and polish up....Invisible repair |
OK amateur paint shop man here so may need further help: 1. Clean area with spirit to remove wax & crap 2. wash with clean water and dry. 3. Start to apply correct colour code paint into scratch with cocktail stick 4. build up very slowly allowing it to stand proud. 5. Allow to dry for ages (not sure how long) 6. Gently cut back with scratch polish or T-Cut until level with paintwork. 7. Wax polish whole panel. 8. Feel very pleased with self! Is the above a good plan or have I missed anything? |
Wait a week before applying the wax - this will allow the paint to go fully off. Less of an issue with touch up paints as the area is so small, but still worth sticking to the basics. |
a few points if i may? clean with IPA - nothing else use paint from aerosol - not touch up stick 'cut' in with a rotary polisher using say Poorboys SSR2 - a machine will do it better/easier than you could ever do by hand if you've gone a bit 'heavy' with the paint i'd use 2500 grade wet and dry paper to remove the'bulk' before machine polishing |
OOps not got a rotary polisher! |
28 days is recommended if you still use non water based paint - but a small scratch should be ok done earlier |
buy the Megs one with a set of pads with these 'amateur' machines you cannot 'burn' the paint if you linger too long in an area you will also be able to use it to remove swirls/holograms/minor scratches from all your cars will save you a fortune |
IPA is available at Maplins: http://www.maplin.co.uk/isopropyl-alcohol-28994 |
Any ideas where best to buy Nick? |
