Home > Maintenance & Mods (L322) > 1/0 Gauge Wire From Battery to Rear on 2011 Range Rover
Jasdip
2011 Range Rover Supercharged 5.0 SC V8 Santorini Black
Hey Guys, I have a 2011 Range Rover Supercharged and am trying to run a 1/0 gauge power wire from the battery to the rear for a sound system.
I found an old thread where a member posted where he ran his wire for a rear amp install; however, my 1/0 gauge wire seems to be too thick to run down that same location. It was along the bottom floor trim panels on the passenger side. the thread is at this link:
https://www.rangerovers.net/threads/amp-su...ver.49297/
Does anyone have a suggestion on where to run this wire instead? I took all the passenger side panels off and had to put them back together, would driver’s side work?
Would running the wire along the outside of the truck be better/only option? If so, where should it be run along to be safe and not be affected by heat, etc.?
Post #547967 22nd Mar 2020 11:37pm
Ansi
Switzerland 2010 Range Rover Autobiography 5.0 SC V8 Adriatic Blue
On the driver side is room enough even for an entire cable loom. I used the driver side on my 2004 when I changed the system to an Android Head unit. It's a pain in the Censored but it’s the only way. Going outside would require an armored cable to be safe.
Post #547978 23rd Mar 2020 7:50am
Jasdip
Thanks for that info! Any tips for running the cable down that side?
The wire harness cover that I have to get under, do I just need to remove the 3 screws and pull it up? I noticed that it extends to further under the carpet.
Post #547979 23rd Mar 2020 8:04am
GGDR
Perhaps amp vs wiring needs a look?
May I suggest you see if you can upgrade your Harmon Kardon amp to HD 1200w (assuming your have standard Harmon Kardon).
PowerfulUK did a YouTube vid plus there are some threads here.
I have the HD system and it is silly loud.
. Cheers, Greg
Post #547981 23rd Mar 2020 8:33am
Jasdip
Did you just upgrade your amp only and keep the original speakers? I watched one of his videos which is the Range Rover Sport L494 Amplifier Upgrade, I’m not sure if that was the one you were referring to.
I have the upgraded 19 speaker Harman Kardon sound system in my truck already. I am happy with the sound from my speakers and even the subwoofers for that matter. My truck just jerks a bit when the bass hits at high volume as I’m driving. I suspect that since the installer took power from the rear fuse box for the aftermarket amps, the vehicle is being starved of power and that is causing the jerking. The rear fuse box voltage drops to under 12V when the sound system in cranked up. The weird thing is that for the first few year when I bought this truck I didn’t have this problem and it started later. The battery and alternator have both been replaced already.
I have 2 Alpine Type X subs and 2 Alpine PDX-M12 amps (one to each sub) installed. The sound system is amazing, it’s just the voltage drop to the fuse box I am trying to eliminate which could potentially cause bigger problems if not taken care of I would think.
Post #547989 23rd Mar 2020 9:49am
Roi354
United Kingdom 2005 Range Rover Vogue Td6 Buckingham Blue
Not only would it be easier to wire but would also protect you better if you fitted a leisure battery in the boot with a split charger.
Just a thought Thumbs Up
Post #547991 23rd Mar 2020 9:55am
Jasdip
I was looking into fitting a second battery into the trunk. I can modify my amp rack in the spare tire wheel well to accommodate the battery and use that same power while I will be running from the main battery to power that battery instead. I even have a battery already that I could use but it doesn’t match the specs of the main battery which was recommended. I currently have a capacitor installed in the back at the amp.
I was told on another forum that the second battery would just be an additional load on the alternator and unless I was listening to music while the engine was off, I wouldn’t see much benefit to that.
I was told to look into a high output alternator instead. Any thoughts on that?
Post #547994 23rd Mar 2020 10:03am
Ansi
I lifted that cover just a bit and was able to push the harness thru. The middle-pillar section is way more of a hassle.
Post #547996 23rd Mar 2020 10:15am
Jasdip
The middle pillar (B-Pillar) was going to be my next question. Did you have to remove the pillar pieces or were you able to get by just by removing the black piece at the bottom of the pillar?
Post #548082 23rd Mar 2020 10:38pm
Ansi
Problem is, you can't remove the black part without partially remove the upper part.
As the 1/0 gauge wire is quite stiff you may be able to push it true without removing the B-pillar pieces completely.
Post #548083 23rd Mar 2020 10:47pm
GGDR
Mine has a factory fit 1200w system.
Yes Thumbs Up
. Cheers, Greg
Post #548085 23rd Mar 2020 11:09pm
Jasdip
I ended up getting it done. That was tough!
I went from the spare tire area (where the amps are) to the fuse box area (right side), then along the passenger side under the trim. At the B-pillar, I wasn't able to go along it since the wire was too thick so I had to cut across the carpet a bit and go under the passenger seat (had to remove the seat). Then back on the other side of the B-pillar and went under the wire harness cover on the passenger side and dropped it into the existing wiring channel. Then up the right side of the glove box. Behind the glove box is a plastic grommet which I drilled a hole in exactly the size of the cable and passed the cable through. I put silicone around the cable for extra protection. Then up to the battery. The battery and battery tray had to be removed to get to the grommet to retrieve the wire from the inside.
I have never done something like this before and was able to get it done, even though it took me many hours!! I doubt the installer would have done as clean of a job as this. If anyone would like more details or has any questions, post a reply or send me a message.
Post #549000 31st Mar 2020 8:30pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Am I missing something here, there is a thick cable running from the battery direct to the fuse box in the rear RHS, why not take a feed from there? I believe like me all those with a second battery make connections from here.
 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #549039 1st Apr 2020 7:35am
Roi354
@wayneg is that part of a DT90? I've been toying with the idea of one of those - if it is, can you share your experience with it?
Post #549053 1st Apr 2020 9:23am
wayneg
Roi354, I grabbed that photo from Google images, I believe its one from the Traxide instructions, http://www.traxide.com.au/diy-dual-battery...t90-c.html
I did my dual battery set up from scratch, it's very simple. From that thick red cable at the fuse box, I ran a cable to a voltage sensing relay then to the 2nd battery. The battery fits in the well in front of the rear fuse box. Traxide has a very good reputaition so you can use their kit or DIY the parts
 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #549055 1st Apr 2020 9:48am
