![]() | Home > Technical (L322) > USA 2007 Supercharged won’t start. No crank. Immobilized ? |
| Laurie915 Member Since: 11 Sep 2011 Location: Canberra Posts: 72
07 Models in UK did have a run of bad ignition switches, all describing similar problems. Not a big job if your handy !
| DucatiBrandon Member Since: 22 Feb 2020 Location: Arizona Posts: 19
Thank you. I’ll swap it |
No luck. Anyone have an idea before the stealership gets it? |
Brandon
That’s a different issue but the button sequence is the same. Mine just won’t crank over. My locksmith came back out and took the small computer (immobilizer) with him and did some testing in his office. He said he found 4 keys programmed and was also going to try and do some computer reset on Sunday. I figured he could try before she gets sent off to the dealer.
For those of you who care we found the issues.
That's good news Brandon ! Water ingress is a problem with some cars, it really is a hit or miss with the car you buy. Enjoy the wonderful engine |
Thank you for the response as I love this thing. Unfortunately She died on the highway a couple days later. Won’t start but she cranks and Cranks and cranks. I put a new fuel pump and kit in but still no luck. She has a lot of fuel pressure. I metered the coils and wire 2 is holding at 4.78 vdc and not pulsing. I wonder if the regulator in the fuel rail is bad. Any ideas |
Crank angle sensor ?
| tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 343
Two thoughts:
| All times are GMT |
