Home > Maintenance & Mods (L322) > Rear towing socket electrics |
Jon G Member Since: 02 Dec 2016 Location: Leicester Posts: 120 |
When i got my Car i swapped the 2 7 Pin Sockets for a 13 Pin one to suit the Caravan.
25th Mar 2020 9:22am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4202 |
A 13 pin genuine LR lead is easy to fit and is plug and play on your model year. The only tricky bit is fitting the rubber grommet through the body (use silicone spray as a lubricant).
25th Mar 2020 9:34am |
Mousey Member Since: 22 Mar 2020 Location: Leicestershire Posts: 20 |
Thanks to you both for suggestions but as I need it urgently it's gone into dealer this evening for work thursday, Fingers and credit card crossed.
25th Mar 2020 5:29pm |
As above, easy and cheapest fix is to swap the plug. They shouldn’t charge you an arm and a leg as it’s a quick plug and play! There is nothing that can't be fixed with a hammer😜😜
25th Mar 2020 9:34pm |
Let us know what they charge you for it. A new 13pin genuine loom was around the £80 mark I think....Time to fit = <1hour. 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" New Defender D300 90 on order so "Rory" will be going to a new home....! 1974 Series 3 Lightweight = "Millie" My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
26th Mar 2020 8:57am |
All done and dusted, dry joints in back of socket, Happy Bunny!! |
28th Mar 2020 8:56pm |
