![]() | Home > Maintenance & Mods (L405) > Early L405 AB auxilliary battery |
thankyou for that info Rob.. |
jettec Member Since: 16 Jul 2013 Location: Melbourne Posts: 229 ![]() ![]() ![]() |
Thank you for sharing.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8061 ![]() ![]() ![]() |
Have you replaced the main battery too ?
roberlar Member Since: 16 Feb 2019 Location: Buckinghamshire Posts: 203 ![]() ![]() ![]() |
Yes I replaced the main battery a few months ago (which was actually still good as I have it fitted to a telehandler now) so the battery monitor obviously doesn't discriminate between the two. The aux battery is genuinely at end of life. The main problem I had is almost all info leads you to the very small EK 151 @ 15ah and 200CCA whereas the correct battery for the early AB (or certainly mine) is the EK 700 @ 70ah and 760 CCA which is vastly different. On top of that you cannot see specification info on the original JLR Exide battery without disconnecting and removing which I was reluctant to do without having the new correct battery to fit due to possible electrical issues. Add to that if you search Halfords and compare their 096 AGM to the L405 (which is the same as a EK 700) it says it will not fit. The same applies to Amazon if you search the EK 700 and most other battery suppliers as well. I seem to recall seeing an image you posted which shows your battery to be the same as mine so as said, that's what it is. The saving grace was an online uk firm called Advanced Factors who show a very useful diagram of the L405, the battery location and battery type. My AB has the executive rear seating with another cooler etc. so maybe that spec together with FBH and so on has higher demands on power hence the big aux battery?
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3926 ![]() ![]() ![]() |
So my car got two batteries - you learn something new every day |
Main one is undertake spare wheel. Secondary is here -
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
Site sponsor. ![]() 2008 Stornoway Grey 3.6 Tdv8 Vogue - SOLD 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT-Sold |
