![]() | Home > Technical (L322) > inactive airsuspension messege |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 ![]() ![]() ![]() |
ive just fitted my new airspring but now i cant turn off the airsuspension inactive messege ive tried the steering wheel trick and ive now disconected the battery and left it for a while ...does anyone know how i can sort this out as my diagnostic equipment will not get rid of this messege and untill it goes i cant test pump my suspension up "RANGEISM WILL NOT BE TOLERATED"
bump "RANGEISM WILL NOT BE TOLERATED"
i thought trhat may work but the front is all the way down so not sure if this will do any harm "RANGEISM WILL NOT BE TOLERATED" www.futuresecurityservices.co.uk Pretlove says , '' I want my car back ![]() |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2074 ![]() ![]() ![]() |
Gosh you expecting a reply in 10 minutes during the normal working day ![]() ![]() Re-set required - needs plugging in. ![]() |
lol that 10 mins felt like hours .....any idea what i should expect to pay to get it pluged in "RANGEISM WILL NOT BE TOLERATED" www.futuresecurityservices.co.uk Pretlove says , '' I want my car back ![]() |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3260 ![]() ![]() ![]() |
£55-65 |
i spoke to a few indi's and they all seem to be saying thats what needs doing but i cant get the car to them but when i spoke to land rover they said on that year it should not need reseting.....and said maybe my ride hieght sensor arms are bent but ive checked those and they seem fine plus i cant see how they would be damaged as they was fine before the airbag was changed ....does anyone else have a 2003 range and have had to have theres reset as id be gratefull to here from you "RANGEISM WILL NOT BE TOLERATED"
Take a chance and go for a drive, it can't go any lower than what it is now. |
Try the EAS Activate for resetting and code reading.
oodathort Member Since: 01 Nov 2010 Location: just there Posts: 191 ![]() |
I suspect that your air tank is empty you can short the pump to fill or get a compressor to fill but only do this with great care you will find that your system will work again with some pressure in tank but wont work without pressure |
i did and nothing happend ![]() ive been looking at that eas tool i was kinda hoping i could find some software to use on my obd2 tool but so far have had no luck "RANGEISM WILL NOT BE TOLERATED" www.futuresecurityservices.co.uk Pretlove says , '' I want my car back ![]() |
there is air in the tank but the air system needs recalibrating i think there is a way to get the air into the front bags by using a jumper on the eas ecu "RANGEISM WILL NOT BE TOLERATED" www.futuresecurityservices.co.uk Pretlove says , '' I want my car back ![]() |
The air valve set up is under the drivers foot well area try swapping the air pipes around to pump up the front or get compressor to pump them up i then think your system will reset if its only front thats down |
thanks ill give that a try "RANGEISM WILL NOT BE TOLERATED" www.futuresecurityservices.co.uk Pretlove says , '' I want my car back ![]() |
