![]() | Home > Technical (L322) > Rear seat recliner and backward,forward adjustment not worki |
bruce Member Since: 21 Jun 2009 Location: Cumbria Lake district Posts: 90 ![]() ![]() ![]() |
Newly acquired 5.0 SC rear seat electrics appear to be dead, I have checked the fuses which are OK any other quick fixes? If you are not part of the solution you are part of the problem!! |
Do you mean the rear window lock out switch? If so yes I have tried that. If you are not part of the solution you are part of the problem!! |
Have you been trying them with the ignition on or off? As they time out after a specific time period... |
Engine running. If you are not part of the solution you are part of the problem!! |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3556 ![]() ![]() ![]() |
Yes. Failing that and wot Craig said if you are confident about fuses then a bit of detective work I guess. Can the passengers seat be controlled from its own switches? (Fore/aft) Do both rear controls not work or just one? Do the heat/cool dials light up and work the climate seats? Can the rear windows be operated from their own rear controls? . . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
Front passenger seat is ok, rear windows work from the switches in the rear, heating and cooling switches illuminated. The two fuses are both 20 amp and are both good. If you are not part of the solution you are part of the problem!! |
Rear heating and cooling actually works though?
I’ll check the lockout switch, I’ve run two scans and found several faults which I have cleared but the seat issue is not coming up. I will also check to see if the heated seats actually heat. I can’t understand why it’s not showing as a fault. If you are not part of the solution you are part of the problem!! |
What’s the wiki? If you are not part of the solution you are part of the problem!! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35833 ![]() ![]() |
top right of page.. ... - .- -.
Sorted the seat issue, went into the CCF deleted all the functions that didn’t work, then went back in and showed them fitted and hey presto they all work.
