![]() | Home > Maintenance & Mods (L322) > White Smoke Cloud L322 4.4. TV8 |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3239 ![]() ![]() ![]() |
if you are getting limp mode, a recurring DPF amber and red and full DPF, then I would suggest you have an air leak, possible any of the 4 pipes to the plenum on top of the engine, or a cracked inlet manifold (passenger or driver side).
maxg67 Member Since: 10 Jan 2020 Location: Verbania Posts: 12 ![]() ![]() |
Thank you Dolphinboy,
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3553 ![]() ![]() ![]() |
Does sound similar to another white smoke report here:
Also welcome!
Just re-reading your issue, an air-system leak it could have caused the smoke, given you found one loose hose this could have been the case. Maybe. I would monitor it.
Thanks GGDR,
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1026 ![]() ![]() |
The colour of the smoke indicates the type of fault you may have, white smoke is air in the fuel. Hopefully you have found the problem with the loose hose |
