Home > Technical (L322) > EGR Leak/Replacement 4.4 TDV8
jackie-o
Netherlands
Hi all,
Thought I´d again ask the wisdom of the forum;
Has anyone replaced or repaired an EGR valve on a 4.4 TDV8?
My car is currently with the mechanic and striped away from inlet manifolds etc.
He has quoted me 11 hours of labour to remove and replace the EGR, replace the 2 gaskets on the oil cooler, replace the o-rings on the oil feed pipe and put everything back together
Does this sound reasonable?
cheers! RR Vogue 4.4 TDV8 - 11
Toyota Land Cruiser Prado - 02
LR Discovery 4 SDV6 -11 - Gone
RR Vogue 3.6 TDV8 - Gone
Post #547333 16th Mar 2020 4:23pm
jackie-o
Netherlands
Has nobody had an EGR replaced on a 4.4 TDV8?
Asking not so much for myself anymore, only this seems to be an uncommon fault? RR Vogue 4.4 TDV8 - 11
Post #548625 29th Mar 2020 12:31am
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
Goedemorgen, kan je helaas niet helpen, maar misschien krijg je eerder antwoord als je "EGR replacement" toevoegt aan je titel. Overigens lijkt anderhalve dag werk me wat ruim bemeten.
Regards
Robert
Post #548631 29th Mar 2020 8:51am
GGDR
It's not a common failure jackie-o
Mike (Baltic Blue) has a thread with the most common 4.4TDV8
Note my thread which clarifies issue and fix for this error code
P040D-00 (2F) Exhaust gas recirculation temperature sensor A
https://www.fullfatrr.com/forum/topic50202.html
You might want to check that out because the error code is for the EGR but that sensor (Sensor A) is nowhere near the EGR.
11 hours for your job does sound a bit high because access is all from the top.
. Cheers, Greg
Post #548633 29th Mar 2020 9:18am
Fox889
jackie-o: Sorry, cannot help you with the EGR labour time, but, having car OCD I would consider replacing your oil cooler rather than replacing just the gaskets. Simply because all the time and labour to do your EGR and if in the future your oil cooler fails, then that's a 4.5 hours job just on it's own. I had the dreaded oil cooler leak [whether it was just the gaskets I don't know] but the local Indy changed the oil cooler itself [genuine LR]. Total job came to £700. If I had put my foot down & said "just change the gaskets" I'm sure they would have but we chose to do the complete job. Think a genuine LR oil cooler is around £300 +/-
You've got enough expense on your hands without some clown popping up saying "change your oil cooler" but hey ho, we're all different. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #548636 29th Mar 2020 9:26am
jackie-o
Netherlands
@fox889; makes complete sense what you are saying. The only thing that makes me reluctant is that no one seems to have an issue with the actual cooler breaking, its always the gaskets...but maybe you´re right and it´s worth just changing the whole thing...
@Robert, bedankt and done
@ GGDR thanks for the directions, these threads/guides really are amazing. In my case tho the whole problem stems from an boost air leak traced to the EGR. They are changing the gaskets either side but they also suspect the valve is faulty and will know one they have the whole thing out and apart.
Aside from o-rings and oil cooler gaskets; are there more things I should change while they have everything apart? The 4 short hoses from the inlet manifold seem to be a given. What about CSOV or other pipes/hoses?
Or better to wait until things actually break?
cheers and stay safe! RR Vogue 4.4 TDV8 - 11
Post #548929 31st Mar 2020 9:39am
kevinp
I just replaced my four hoses with some silicone tube. 500mm length for £11 from amazon.
Post #548989 31st Mar 2020 7:16pm
jackie-o
Netherlands
@ kevinp; These are 30 gbp each from LR so gbp 120 for all four...you do mean the 4 short hoses from the air intake manifold right? RR Vogue 4.4 TDV8 - 11
Post #549074 1st Apr 2020 1:17pm
kevinp
Yes mate. I just cut the hose into 4 x 56mm lengths using the jubilee clip as a guide to cut it square.
Post #549093 1st Apr 2020 4:45pm
jackie-o
Netherlands
Another small update on this;
Hopefully the EGR is fine after all. The indy has found an air leak coming from a pipe going from the oil separator to the oil filter housing and this is apparently leaking air?
Does anyone know what he is talking about? RR Vogue 4.4 TDV8 - 11
Post #552140 30th Apr 2020 12:46pm
Fox889
That's a new one on me Jackie-o if I'm honest.
Be interested in finding anyone who does know? 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
1973 Honda CB250 K4
Post #552228 30th Apr 2020 9:41pm
Ive only ever changed one 4.4TDV8 EGR and it was a Censored job! Im glad they don't want changing often!
Post #552238 30th Apr 2020 11:06pm
jackie-o
Netherlands
@Craig; thats pretty much what he said too...
The theory is now that the leak is coming from a steel pipe going from the EGR (couldn't understand exactly which one)
He has tried looking with a a camera but it´s too tight to see anything and the whole thing now needs to come out which apparently is a real PITA Sad
The saga continuous... RR Vogue 4.4 TDV8 - 11
Post #552279 1st May 2020 12:03pm
jackie-o
Netherlands
So a small update for those interested.
EGR and a lot of other stuff now out and it turn out the EGR was bad as well as the pipe leading back to the inlet manifold.
All parts arrived today and the mechanic is very much looking forward to putting it all back together again.
According to him, apart from turbo replacement , this is pretty much the worst job you can do on this engine...
Post #553035 7th May 2020 1:22pm
DrRob
Keep us posted and fingers crossed it cures your issue. Is it obvious where the damage is? Please post some pictures Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #553044 7th May 2020 1:36pm
