Home > In Car Electronics (L322) > 2011 TDV8 4.4 iphone cable
klf400
Ok guys had this car a few months finished repair as was a salvage vehicle, but now I want to connect my iPhone to stream music , I have no lead and the ones available don’t have the lightning connection just a chunky plug either end , connected phone to system via Bluetooth but only makes and receive calls can’t find a way to play music, do I need a different cable or am I missing something here 🤔 1990 3.5 v8 defender
2000 4.6 v8 30th anniversary prins lpg
2004 4.4 v8 vogue prins lpg
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #548632 29th Mar 2020 8:16am
GGDR
You need a BoVee
https://www.amazon.co.uk/Bovee-Integration...B01N9EQ5PW
We also need the full story of your car with pics please!!!
Thumbs Up Thumbs Up Thumbs Up Cheers, Greg
Post #548635 29th Mar 2020 8:24am
klf400
Cheers for that will order one you would of thought a car of this distinction would have had an easier way to stream music but I guess the design stage would have been several years earlier 🤔
Bought the TDV8 4.4 in early February from salvage yard , only went to the yard to look a a fiat 500 which was sold then I turned around to see the fatty and gave it a good look over then bought it
Was cat N so no marker on registration document, damage was light , front bumper and crash bar were both damaged could of repaired them but was easier to get replacements , had alternator fault also front cameras and parking sensors not working but this was due to the loom being severed on the impact, guess that’s why insurance wrote it off (could of been a can of worms) anyway took the front end of bumper, crash bar, slam panel ,radiator pack , after draining anti freeze and AC gas , followed by the fan , front end of sub frame to gain access to the inter cooler pipes etc , changed belts and idlers and alternator ( old alternator was not charging so the fatty would not run for long until everything shut down) ( also without taking the front end of the car of you would find changing the alternator impossible)so put the rad pack back in filled with antifreeze connected all the multi plugs and fired her up and all is good ,
Didn’t take many pictures but I have a few
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #548777 29th Mar 2020 10:37pm
mjdronfield
I thought you could just buy a genuine 30 pin to lightening connector and use the iPod connector under the arm rest.
Thought that’s what it was for?
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #548784 30th Mar 2020 8:19am
klf400
Yeh I guess that’s an option as well , the other suggested would be Bluetooth without plugging the phone in 🤔 1990 3.5 v8 defender
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #548806 30th Mar 2020 10:48am
Weegie
The cable adapter suggested by mjd would be a lot cheaper and would charge the phone at the same time. John
GAP iiD BT-Sold
Post #548809 30th Mar 2020 11:02am
GGDR
It's just that 30-pin iPod cables converted to lightening don't really work all that well if at all. Eg sometimes they don't even charge the phone
The Bovee's control track skip whatever your music source within your phone. It also allows for receiving calls.
They can also be had cheaper (sometimes they come up for sale here on fullfat) but try ebay too.
Do a search here plenty of discussion on this topic.
Bear in mind that it's 2011 technology so your phones have shot ahead in terms of software and also connectors but the car remains stuck in 2011.
. Cheers, Greg
Post #548812 30th Mar 2020 11:15am
GGDR
Does Cat N remain on the insurance database though?
. Cheers, Greg
Post #548813 30th Mar 2020 11:17am
millerj90
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
A proper Apple made 30 pin to Lightning connector works fine on all counts when connected to the LR cable. Its what I use all the time.
I think the problem comes when people purchase the non-apple "clone" converters
Post #548826 30th Mar 2020 12:51pm
mjdronfield
Yeah, that’s why I put genuine in my post. I dare say others work, but it does seem a bit hit and miss.
I use CDs still. Only just got rid of the 8 track....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #548861 30th Mar 2020 3:32pm
millerj90
Sorry, ustve missed that bit Embarassed
Post #548870 30th Mar 2020 5:26pm
klf400
that I have no idea 🤔 1990 3.5 v8 defender
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #548946 31st Mar 2020 10:12am
GGDR
have you had to declare it to your insurer?
if so did the quote reflect it?
. Cheers, Greg
Post #548948 31st Mar 2020 10:21am
klf400
Yes I told them and it didn’t make any difference but maybe with another insurance company it would 1990 3.5 v8 defender
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #548949 31st Mar 2020 10:30am
