![]() | Home > Technical (L322) > 5.0 SC power steering pump. |
bruce Member Since: 21 Jun 2009 Location: Cumbria Lake district Posts: 90 ![]() ![]() ![]() |
Can anybody point me in the right direction for the part number of or alternativel source for a pump. Lakeland Land Rover are shut so I can’t get a part number and I imagine the cost for a genuine new unit will be eye watering. Mines leaking. If you are not part of the solution you are part of the problem!! |
The only one I can find non genuine is in Germany, any ideas for a UK supplier? If you are not part of the solution you are part of the problem!! |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 709 ![]() ![]() ![]() |
Island 4x4 or Britcar are usually pretty good if you know what part no. you want.
Thanks, I just need to find the correct part number and I’ll give them a call. If you are not part of the solution you are part of the problem!! |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3269 ![]() ![]() ![]() |
I believe it is LR011844
Thanks, I spoke to Britcar, unfortunately they only have genuine which is eye watering. I have gone for the Mapco version at £165 from Germany. If you are not part of the solution you are part of the problem!! |
It probably doesn't help now, but you might be able to get it considerably cheaper via the ZF part number if you can find it (ZF are the manufacturers for land Rover) Paul,
