Home > Technical (L322) > 5.0 SC fan
bruce
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Stornoway Grey
5.0 SC fan
As soon as I stop the car main engine cooling fan kicks in and runs continuously. Car is it only showing normal temperature and the only way to stop the fan is by removal of the 50 amp fuse. Opening the drivers door also stops it any ideas what’s causing it I’m assuming a faulty thermostat but where the hell is that located If you are not part of the solution you are part of the problem!!
Post #549151 2nd Apr 2020 12:15pm
Baltic Blue
Their is a Workshop Manual in the wiki solely dedicated to the 5.0l engine, which should answer your questions.
Post #549156 2nd Apr 2020 1:04pm
bruce
So it appears that the ECT module is faulty but where is it actually located? Any ideas. If you are not part of the solution you are part of the problem!!
Post #549161 2nd Apr 2020 2:18pm
GGDR
Not sure but I'm also a 5.0 fan.
Laughing Laughing
. Cheers, Greg
Post #549162 2nd Apr 2020 2:34pm
lockdown is getting to you Greg..... Shocked
Laughing Thumbs Up ... - .- -.
Post #549163 2nd Apr 2020 2:37pm
