![]() | Home > Off Topic > Mini arc welder on amazon - any good? |
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561
HI guys,
| paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 358
What sort of things are you planning to do Greg?
| ur20v Member Since: 19 Feb 2019 Location: None Posts: 634
Note these little arc welders are normally over rated- if it says 140amp’s, it’s likely to be nearer 90-100amp’s maxed out, still enough for 3-4mm Metal |
| m@ttsFF Member Since: 12 Dec 2017 Location: Surrey Posts: 338
I’d also recommend going with a MIG welder . It will do all that the small stick machines can and much more
thanks a lot guys of the feedback, will check out the mig options.
Note the reason I mentioned flux core for outside and CO2 bottle shielded for inside is because in wind situations the CO2 gas shielding can be blown away, if you weld on a still day or can make up a wind block you will be fine and get better results than with flux core. Some machines do both which may be an advantage.
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35880
bought my youngest son a power devil mig for xmas..all the reviews were positive and it only cost £60....it also has a non live? handle ??. ... - .- -.
Who knew Stan or Corbyn could weld. |
| All times are GMT |
