Home > Technical (L322) > L322 Camera - Replacement Rear View Camera Recommendations
capesthorne
Hello all,
Hopefully a very quick question, can anybody recommend a good quality replacement rear view camera?
There are many posts on this site that are many really helpful in walking through the diagnosis of duff cameras and how to remove the modules from the car, but the cameras listed are often shown via out of date eBay links.
I’m looking to keep the original housing and to fit a replacement camera inside. Is there a ‘go to’ model that is used? Or is it a case of try your luck on eBay? I’m guessing reversing lines/guides on screen is just personal taste?
Many thanks. Thumbs Up
Bryn
Post #549294 3rd Apr 2020 11:47pm
Ian928
Norway 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Just installed the one below. Good YouTube instructions and no soldering or special tools needed. Very good Picture except the camera has a narrower angle so show only the ground behind the car.
https://www.ebay.com/itm/L322-Range-Rover-...SwZb9doL7v 2006 Supercharged
Post #549485 5th Apr 2020 7:18pm
capesthorne
Thanks for posting this, it’s taken me a while to reply, apologies.
I also went for the eBay route, albeit a different camera....well it might have been the same camera in a different box.
This is the unit I purchased:
https://www.ebay.co.uk/itm/Car-Reversing-R...890.l49292
I had to disassemble the existing camera and glue the new unit in place of the existing camera, it fitted really well. The connectors had to snipped off and soldered onto the new camera.
The quality is ok, I really need to compare it with a car that still has a fully functioning original camera to be sure. What I couldn’t find was a genuinely high quality camera, there must be one out there. Powerful are selling one for £100 or so, but again are they just taking a cheap camera and re-boxing it?
The upshot is, I have a working camera and can see behind pretty well.
Post #579945 16th Jan 2021 9:58am
NJPovey
Just to add to this discussion my son helped replace the camera on my old RR when it failed. He used a drone camera, there are many good ones available and some are almost universal in that you can set PAL/NTSC aspect ratio etc. Just need the correct lens for field of view. In my installation we simply removed the old camera from the housing, cut out some of the internal plastic and the "glass" window and then mounted the new camera with sticky pads and sealed around the lens with sealant so the glass window wasn't needed. Its been good for 2 years now. An example of the type we used is here: https://hobbyking.com/en_us/foxeer-predato...black.html They come with cables so just a case of soldering the correct wires together...... 2012 L322 Westminster V8 - Current
Naylor TF1700 - No. 55 of 100 Built - Current (on dry days)
2006 L322 Vogue TD6 146,000 miles- Current
Fiat Panda 1.3 Multijet 145,000 miles - Current
MG ZTT CDTi Estate - Sold when approaching 250,000 miles
2 1/4 Petrol 1972 Series III Sold
TD300 Discovery Long gone, but not forgotten
Post #579957 16th Jan 2021 12:30pm
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
Well i am really surprised at how bad RR offering is compared to my navara.
0 night view at all even under street light you cannot really see.
the guides that come up in the screen do not move with the steering wheel.
My Navara had night vision and the guides worked really well. poor show from RR in my view so am thinking of upgrading at some point 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #579963 16th Jan 2021 1:24pm
lschwarcz
United States 2009 Range Rover Autobiography 4.2 SC V8 Bournville
JayK69,
Maybe I missed it from an earlier post but can you point the rest of us to the source and what model? Any details on the install? if this was covered in an earlier post maybe the link to the thread?
Thanks!
Larry. 2009 Range Rover L322 Autobiography
Bournville/Ivory
Save lives, give blood.
Post #580013 16th Jan 2021 6:00pm
Jayk69
Ischwarcz
I was just pointing out how poor the reversing camara is on my 2012 TDV8 Vogue is compared to my 2014 Navara Outlaw,
if i find a better alternative i will defiantly post what i have done 2012 Vogue 4.4 TDV8 - Current
Post #580015 16th Jan 2021 6:06pm
NobbyC
United Kingdom 2005 Range Rover Vogue 4.4 V8 Buckingham Blue
Replacement options can also be found here https://www.luxurylandroverupgrades.com/shop. His prices have gone up a fair bit since I had one off him but its far better than the original and no problems over last 4 years.
Post #580043 16th Jan 2021 9:05pm
Gordo51
Canada 2008 Range Rover Supercharged 4.2 SC V8 Barolo Black
I installed the basic model from LuxuryLandRover, the one that requires you to take the old camera apart. I am not impressed. No better than the original camera except it has guide lines. Picture washed out. Next model up is same camera but already fitted in a housing so I would not buy that. Need to go for their most expensive version to get real improvement but I have not tested that one so just assuming.
Post #580700 22nd Jan 2021 2:04am
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
That luxury land rover upgrades shop is a shambles. Breaks so many rules and regulations I would never order from there and through there.
Please people be very careful. Besides the legal side of things, any online shop not even bothered matching their email address to their domain in 2021 is just nuts.
Post #580716 22nd Jan 2021 9:27am
Ianb4310
And ridiculously expensive
Post #580723 22nd Jan 2021 10:05am
Pikey
PowerfulUK do replacement cameras, designed as a straight replacement for about £100 Pikey by name, not by nature Smile
Post #580756 22nd Jan 2021 2:30pm
Ianb4310
There’s a wiki to do it for about £15
Post #580758 22nd Jan 2021 2:44pm
