![]() | Home > Maintenance & Mods (L322) > loud clicking from behind dash |
gj88 Member Since: 10 Sep 2018 Location: West Midlands Posts: 213 ![]() ![]() ![]() |
How did you get on with this in the end John? It's definitely this part that's the problem, but I've taken it apart and cleaned it up, no joy, ordered a second hand used part for a fiver to see if it made a difference, and that one's even worse! |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 619 ![]() ![]() ![]() |
I have the same problem. Took the whole thing apart and re-greased and for a couple of entries the noise was gone only to return as loud as ever.
JohnK Member Since: 15 Mar 2020 Location: Hampshire Posts: 61 ![]() ![]() ![]() |
Not too well, stripped and totally cleaned twice now, its not as loud and the pattern of clicks seems different but still not right. Going to go down the lines VS322 has said when I get the chance, im cutting out the rust in the rear arches / sils at the moment. |
Pulled the thing out for the Nth time this morning leaving it connected to the wiring. Locked the car and let it sit for 30 or so minutes. Unlocked and opened the door. The motor moved its 90 degrees travel silently.
I've had some success so far, it would seem the gearbox wasn't fully engaged.
Thanks for posting this, John. I'll give it a try and report back. Glad it worked for you |
I give up on this one. I can confirm the gearbox is indeed engaged.With the motor removed and gearbox in place, I was (again) able to move the gears a full opening and closing cycle of the damper.
Roi354 Member Since: 06 Feb 2020 Location: Essex Posts: 32 ![]() ![]() ![]() |
Are you certain the door moved by this device is moving freely?
Yes, I'm sure it's moving freely but can't be sure it's really the full range. It may very well be some detached piece of sealing foam preventing the damper from reaching it's fully open or shut position. But I can't confirm or rule this out without taking the entire console apart |
Im still looking for where I read about no feedback loop so im sure its to do with timing.
Found it.
By way of update and addition to the knowledge base:
