Home > Maintenance & Mods (L322) > LED interior upgrade
Panoramix
Italy
did a few weeks ago, just in time before the Covid lock down Embarassed
Pics doesn't shown exactly the final result. Dimmer function still works so, the new lighting is not annoying while driving.
I love it! Cool Cool Cool
Post #549933 11th Apr 2020 6:15am
ur20v
A Trap
Looks great.
I have been thinking of doing this as I hate the oem green lighting.
Post #549935 11th Apr 2020 8:17am
ur20v
A Trap
Any tips, anything difficult or you would do differently?
Post #549936 11th Apr 2020 8:17am
Panoramix
Italy
You need to remove a lot of trim.
Gloveboxes, dashboard top panel, doors card, etc.
you need a lot of patience and courage Laughing
Be very very carefull removing the instrument indicators.
Post #549939 11th Apr 2020 8:43am
FrankN
Germany 2004 Range Rover Vogue Td6 Bonatti Grey
It looks perfect , has you more pics from the parts and building
Best regards
Frank
Post #549945 11th Apr 2020 10:04am
Danwilderspin
How do you remove the instrument needles? I pulled them on my original l322 and wrecked the motors - I have the same style one as you now and need to get them off wondered if any different? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #549948 11th Apr 2020 10:13am
Panoramix
Italy
For the earlier L322 is very very easy broke them pulling out.
In this version you can. Pull them up gently Thumbs Up
Post #549981 11th Apr 2020 1:38pm
Panoramix
Italy
Best regards
Frank
I'm sorry FrankN, I didn't. Crying or Very sad
Post #549983 11th Apr 2020 1:46pm
Weegie
Quote:
Best regards
Frank
Could you list the parts required? John
GAP iiD BT-Sold
Post #549985 11th Apr 2020 1:52pm
Panoramix
Italy
Only SMD 3.5 LED, soldering iron and patience.
You need to replace the LEDs on PCBs so, LED colour at your choice Cool
Post #550012 11th Apr 2020 6:39pm
Weegie
Thank you. Thumbs Up John
GAP iiD BT-Sold
Post #550013 11th Apr 2020 6:40pm
Danwilderspin
What’s the safest way? Maybe slide a fork in and gently lever out? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #550015 11th Apr 2020 6:49pm
rjff
If you are removing any instrument gauge needles, you should use one of these to avoid pulling the shaft away from the driving mechanism.
https://duckduckgo.com/?q=instrument+panel...Puller.jpg
or you could make one if you have the means.
perhaps I should add if the needle has no hole to allow this, then the gauge may not be intended to be calibrated/repaired or disassembled. your call then on a fork!! Cheers
Richard
Gap IIDBT
Post #550017 11th Apr 2020 6:58pm
RichM63
France 2006 Range Rover Vogue TDV8 Stornoway Grey
Great job Panoramix and kudos for the attention to detail. Thumbs Up
Your lighting looks sweet. Bow down
Rich L322 3.6 TDV8 Vogue. 07MY
ML 320 7 Seat full leather etc. (The Black Pearl) Wink
Post #550021 11th Apr 2020 7:15pm
Danwilderspin
Hi thanks for the tips - what leds did you use as I may do mine can you get different brightness as I had white ones fitted to my old l322 and they were so bright at night but I couldn’t turn down the rheostat as you couldn’t see the green on anything else... Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #550741 17th Apr 2020 11:57pm
