Home > Maintenance & Mods (L322) > Battery Replacement
Springer
United Kingdom 2003 Range Rover Vogue Td6 Galway Green
Battery Replacement
Hi all I recently replaced the battery in my 2003 TD6 Vogue do I have to reset any think with the Gap Tool if so how.
only just acquired a Gap tool so still learning thanks for your help once again
Peter 2003 TD6
Post #550180 13th Apr 2020 12:03pm
as soon as the new battery was fitted and with the engine running , you should have turned he steering wheel fully left and then fully right ..
no iidtool adjustments are necessary.. ... - .- -.
Post #550183 13th Apr 2020 12:07pm
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
Hi Springer, as far as I know you don't have to reset anything that requires a special tool. I changed mine on a 2004 TD6 and just had to re calibrate the sunroof by opening all the way, hold switch in the open position for 5 secs then the same when closing, all was fine there after.
Post #550184 13th Apr 2020 12:07pm
diesel Dave
Oh yes, and as Stan says the steering side to side Thumbs Up
Post #550185 13th Apr 2020 12:09pm
Springer
Great all done then thanks once again 2003 TD6
Post #550205 13th Apr 2020 1:53pm
