|  | Home > Maintenance & Mods (L322) > Oil Leak 4.4TDV8 (Not oil cooler) Help needed |
| Nick591 Member Since: 04 May 2017 Location: Seaton Dalaval Posts: 193    | Unless the seal itself has failed (which it may have but would be unusual) a cause could be pressure in the crankcase due to a blocked crankcase breather system or valve. How many miles on the engine? Have you got any error codes? Do you do a lot of short trips which could cause build up of gunk in the breather (PCV) system?
|  13th Apr 2020 7:30am |
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561      | Hi Charles, Nino Nino found an oil leak front of engine on his 2012. Can’t remember details but have a search?
|  13th Apr 2020 8:27am |
| nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690      | Charles89
|  13th Apr 2020 8:41am |
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561      | Nice one Nino.  | ||
|  13th Apr 2020 8:55am |
| Charles89 Member Since: 11 Nov 2018 Location: Leicester Posts: 268      | Thanks everyone, so just to confirm Nino, this was caused by your oil pump? And what exactly was the issue? Was it oil seals or new pump required etc.?
|  13th Apr 2020 10:56am |
| nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690      | It was just the plug on the top of the oil pump. loosen the plug apply some silicon and  that was it. 2012 TDV8 Black Edition
|  13th Apr 2020 1:32pm |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352      | I had the same. Rovertune fixed it whilst doing other work. Same fix as Nino describes   | ||
|  13th Apr 2020 1:33pm |
| Posting Rules
