![]() | Home > Maintenance & Mods (L322) > Oil cooler - 3.6 TDV8 |
jonminns Member Since: 07 Mar 2011 Location: Leicestershire, UK Posts: 155 ![]() ![]() ![]() |
Well, got the missus to come and have a look, she solved it first time!
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16366 ![]() ![]() ![]() |
Glad you got it sorted sir |
Nick591 Member Since: 04 May 2017 Location: Seaton Dalaval Posts: 193 ![]() ![]() |
Interesting Jon, was your leak of water or oil and were you able to find out where exactly it was coming from?
Hi Nick,
thanks Jon, very interesting. As you know to see where anything is leaking from in the V is pretty much impossible without dismantling enough to stop then being able to run the engine. Even with a cheap USB boroscope camera with a light on the end I couldn't get anywhere on a finding a location for the leak. There are so many o ring seals around the oil filter housing and PCV assembly as well as the oil cooler that it could be one of quite a few things. Certainly on mine the oil seems to be confined to the left side of the V at the rear and I have sucked out sludgy oil residue from the wells in that side of the rear of the V using an old turkey baster!
