Home > Maintenance & Mods (L405) > New Windscreen Required!!
SS.Lyria
United Kingdom 2014 Range Rover Autobiography 5.0 SC V8 Loire Blue
Got a stone chip a few months back and was hoping to see out the current crisis before getting it sorted, but the crack has now traveled over a foot so think I better get it sorted.
I’ve had a few windscreens replaced over the years but never on any of my land rovers.
I seem to remember a lot of owners on the D4 forum moaning that the replacement windscreens they had fitted were sub standard.
Looking for a heads up on what I should be insisting on having fitted to my RR with my insurance company. Not sure if there are different levels of windscreen that were fitted but mine is definitely heated and topix states that mine is fitted with Acoustic glass, but I’m not sure if that just relates to side windows.
Thanks for any pointers.
Post #550442 15th Apr 2020 9:28pm
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
Have you got head up display? I’m pretty sure that needs a specific windscreen type.
Post #550445 15th Apr 2020 9:46pm
SS.Lyria
No head up display.
Post #550447 15th Apr 2020 10:07pm
Rob99
I'm sure others with L405's can be more specific but my general advice is to take a picture of the symbols etched into the existing screen and insist that the new one matches when you book it in.
Don't be fobbed off and insist on checking the new screen to make sure it's the correct one BEFORE they remove the cracked one.
I also seem to remember someone mentioning that the trims also have to be replaced at the same time? Again, when booking and when they turn up check they have them.
The last thing you want is for them to have to go away and you have a FFRR you can't drive anywhere.
Regarding insurance, insist on a like for like replacement. After all, they charge you a higher premium because your car is higher value and more expensive to repair.
I have a couple of chips in mine but it passed the MOT without advisories so I'm ok at the moment but I'm dreading it when I have to get it done.
Good luck Thumbs Up Thumbs Up 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #550450 15th Apr 2020 10:28pm
Macpaul
2019 Range Rover Vogue SE 2.0 PHEV Siberian Silver
It was no biggie for me.
Autoglass came and fitted the right screen with the right markings. Pilkington?
I told them in advance I was going to be picky and they said, if you don’t like it, we’ll change it.
The one they brought was fine and the blokes (2 required) knew what they were doing.
Pleasantly surprised
Post #550453 15th Apr 2020 11:16pm
make sure the heated part is wired up correctly...its the two thicker cable/plugs ,one on each dide and not the thin ones.... ... - .- -.
Post #550461 16th Apr 2020 5:32am
SS.Lyria
Thanks one and all for the input.
Plenty to make the sure the correct windscreen is installed Thumbs Up
Post #550462 16th Apr 2020 5:51am
When Autoglass did mine, I specified Pilkington on the initial call - they called back to say it would take a few days extra to source one of those - I told them I was fine to wait & have the right one fitted.
Post #550463 16th Apr 2020 6:57am
Mariana Black
England 2014 Range Rover Autobiography TDV6 Mariana Black
I used National windscreens
They were OK but had an issue with the heated screen - I had mentioned to Stan about the incorrect wiring connectors.
I also wanted a genuine screen, I had to settle for one that had a black block covering the words Range Rover as supposedly National cannot fit a Range Rover screen only an equivalent - hence the blacked out name.
3.0 Autobiography 14M5
Post #550481 16th Apr 2020 11:20am
Chalky
I had to replace mine two weeks after I bought it new in 2018. I used Autoglass and they were excellent. I insisted it had to be a Genuine LR screen. Cost me £50. All LR cars from 1984
2021.5 Vogue SE D300 Carpathian Grey
2018 Vogue SE British Racing Green GONE
Post #550487 16th Apr 2020 12:04pm
SS.Lyria
All booked in for Thursday with Autoglass. I have insisted on Pilkington so fingers crossed.
Their web site says they are only working on key workers cars, my wife is NHS so no issues there, but no details were asked for during the booking in process. I’m guessing it’s not quite as strict as the web site suggests.
Hope to report back with a trouble free experience Thumbs Up
Post #550914 19th Apr 2020 8:10am
If you can take it to them all the better. Last few screens I’ve had done were done at the depots. There is nothing that can't be fixed with a hammer😜😜
Post #550927 19th Apr 2020 9:12am
ABAB
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
Autoglass haven’t had depots in the UK for many (5+?) years now - it’s all van based. Or rather when my 405 screen was replaced last year, van x2 as it’s a two man job for that car. 2016 SDV8 AB
Post #550931 19th Apr 2020 9:42am
CS
When my windscreen had a chip repair about two years ago it was at an Autoglass depot. I was told that they had got rid of all the depots and then regretted it, so there were now some again. So you might be lucky and be able to go to a depot, much better IMHO, especially for a bigger and more complex screen like on the RR, and also generally if there is dust/grit blowing around outside, it is raining etc. Only Range Rovers since 1988
Post #550932 19th Apr 2020 9:50am
SS.Lyria
They would only do it at a depot, had a choice of 3. Under normal circumstances would have chosen the one near the RAF museum in Hendon and wandered around there for a few hours Sad
Post #550937 19th Apr 2020 10:36am
