![]() | Home > Wheels & Tyres > Continental vs Michelin Pilot AS 3 vs Pirelli Scorpion Zero |
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
I have just fitted 275/40/23 Pirelli Zero's on mine with the foam "silent" insert and they are amazingly quiet! Have dome zero miles on them to test anything else due to the lockdown but the few miles home made a massive difference in road noise |
| AaronG Member Since: 23 Feb 2020 Location: Las Vegas NV Posts: 4
Ok, thanks. So the pirellis are quieter and they come in 285/40 size as well... I haven’t noticed much road noise from the continentals really but they have worn pretty fast. 19k miles and the tires look worn already. |
| dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724
I found the Pirellis Verdre PNCS ( foam) quieter than than the standard contis. |
| ilard Member Since: 21 Oct 2012 Location: London Posts: 717
If 275 is the width, how does 285 provide extra sidewall if the profile is still 40?
| Bradders Member Since: 03 Dec 2018 Location: Gods own country Posts: 417
I went from Contis to Zeros and the Zeros are noticeably quieter and so far, seem to be wearing better too. Current: FF Westminster money pit
| Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1482
The profile (i.e. Sidewall nominal height) is a % of the width, so in a 40 profile a 285 has a sidewall of 114mm and a 275 would be 110mm 2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black 2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black |
oooohhhhhhh, I see. How embarrassing.
Don't be. I had to have it explained to me some years ago. It's one of those things that, once you know it you kind of go "Oh Yeah" 4mm is very little and that doesn't factor in the "squish" factor when the weight of the car is on it. 2021 D350 Fifty Edition - Carpathian Grey 2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black 2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black |
Thanks, but here in the US the insurance co doesn’t care what size tires we run. I’m actually surprised to hear that you guys would need to disclose that in the UK. |
| ur20v Member Since: 19 Feb 2019 Location: None Posts: 634
In the Uk you can normally tell the Insurrance company of a modification like wheels or tyre size changes and they may either refuse to insure or add a premium and add a note on your policy of the modification.
| JohnGalt11 Member Since: 31 Mar 2020 Location: Iowa Posts: 27
I've never had an insurance company ask about modifications other than how it relates to the value of the car. So if you want your $10K wheels covered under your policy, you'd have to tell them so they can adjust your premium. In the US, vehicle registrations are handled at the state level, not the federal level, so every state has different rules, different requirements, and very different costs. When I lived in New Jersey new cars came with a 3 year inspection sticker, but after that you had to have it inspected every year. The inspection basically consisted of checking that the lights worked, checking the brakes (on a roller), tires for wear, and looking for OBDII codes related to emissions. A check engine light was an automatic fail. Registration was a flat fee of about $70 per year. Some states also measure actual emmissions from the exaust.
| FFRR64Royal Member Since: 18 Jul 2020 Location: Saltash Posts: 130
Just checked the sidewall height and it’s 10mm smaller on the 285,s ?
| qwerty Member Since: 21 Oct 2015 Location: Bristol Posts: 65
that says 45 aspect ratio on the 275's |
So it does.....blumin sausage fingers |
