Home > Technical (L322) > IIDTOOL Code: P1180-01 Low side fuel pressure sensor
Smegordead
United Kingdom 2002 Range Rover Vogue Td6 Buckingham Blue
So been slowly sweeping through the error codes the FF has thrown up - all been pretty minor so far but a new code appeared this week - after a little searching I can't find much that specially relates to my engine so hoping you guys can help.
Has anyone else seen;
P1180-01 Low side fuel pressure sensor plausibility (fuel filter) - reduction in quantity due to low pre-pressure - General failure information - general electrical failure.
If so any idea what I really means? I'm guessing its something to do with low pressure fuel release, maybe at the lower revs?
Phones my local main dealer and got the usual line of "bring it in for diagnostics and we'll let you know" not keen to spend £90 just to do that if it's something simple to resolve.
Thanks in advance 2002 Range Rover Vogue
Post #312093 11th Feb 2015 10:18am
First if you haven' done a service for a while get it serviced.
Some intervals i've seen mention of 20k. This is FAR too long IMO and a diesel should be serviced every 6k as the oil and filters are that cheap, and diesel oil soots up quickly and starts to go cruddy after 15k IMO Ive seen it on a few engines where it drains out in globs at the manufacturer timed service interval Sad
If the issue still pops up then the following needs to be looked at,
Low Pressure Fuel pump(the one under the passenger side rear next to the fuel tank
The intank pump unit could be getting gunge buildup around the intakes on the mesh filters.
I would personally also try some kind of fuel system cleaner. Put the whole bottle in to 1/2 a tank of diesel as it will help speed up the cleaning process Very Happy FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #312099 11th Feb 2015 10:44am
Smegordead
I still get her serviced as per the dash indicator (or timing lapsed) via the main dealer, last one was only about 5k miles ago.
I was really looking to see if anyone else has seen this issue and if so is it a quick self fix.
I will try fuel cleaner this weekend and see what happens.
Thanks 2002 Range Rover Vogue
Post #312159 11th Feb 2015 3:34pm
Be careful of overdosing with fuel cleaner, if you don't dilute it to the manufacturer recommendation you run the risk of "washing the bores", this is when the excess cleaner removes the film of oil on the cylinder bores and causes scuffing of the rings and piston inducing premature wear. Thumbs Up Pete
-Click here for Thread-
Post #312190 11th Feb 2015 6:05pm
To do that kind of bore washing you'd have to be using something like petrol in wuch a strong mix the engine wouldn't fire. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #312260 12th Feb 2015 8:52am
Nads
United Kingdom 2006 Range Rover Vogue Td6 Barolo Black
Hi mate i have a p1180 fault on my range rover l322 any suggestion as what this problem is . While driving at slow speed under 30 mph i am ok as soon as i put my foot down there is power especially on a hill any suggestion please
Post #369781 31st Jan 2016 6:29pm
Nismotec
did anyone get to the bottom of this? ive just started getting the same code with my gap iid.......IIDTOOL Code: P1180-01 Low side fuel pressure sensor...
Post #550562 16th Apr 2020 10:13pm
https://www.rangerovers.net/threads/l322-t...rt.328496/ FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #550567 16th Apr 2020 10:35pm
Nismotec
nice one thanks ill give that a try tomorrow... did it fix your problem?
Post #550569 16th Apr 2020 10:45pm
I can't recall but in the past I've replaced
Injectors
Pump
Injector loom
Low pressure pump
And I blame a bad batch of BioD for that but checked everything else over and it seems grand. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #550598 17th Apr 2020 8:51am
