Home > Technical (L322) > turbo replacement |
gilesharrison Member Since: 04 Aug 2018 Location: Cumbria Posts: 163 |
It's an engine out job so it's pretty involved. I think by the time you bought two new turbos, done all the work to replace them and got the car up and running again, it often isn't economically viable to repair these cheaper TDV8s. Good runners have dropped so much in value you may as well just get one without problems.
18th Apr 2020 9:18am |
robo Member Since: 09 Mar 2012 Location: solihull uk Posts: 32 |
thanks for reply so it cant be done without pulling the engine? which obviously is a lot of work i read of some company was doing it without taking the motor out,if it can be done would give it a go,just seems a shame to scrap a nice car for turbo failure,i work on hgv s so have some decent facilities at hand and time is not an issue, but i see what your saying the prices are dropping for runners is it worth the work, maybe someone else will come forward and tell me if they did it . many thanks again |
18th Apr 2020 10:05am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4232 |
My secondary turbo on 4.4 tdv8 was replaced in a few hours. No engine out malarkey. Don't know about primary one but led to believe it's the same. Probably down to the knowledge and experience of who does the work. I used Rovertune who only work on LR stuff and are highly knowledgeable Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
18th Apr 2020 10:35am |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
If you use the search function you will see people have changed both turbos on the 3.6 without removing the engine, I remember one of the is much easier than the other. When one of my turbos snapped its impeller shaft my indie dropped the engine to changed both turbos, he reckons it was easier than doing it in situ. 2015 4.4 AB
18th Apr 2020 1:24pm |
darrenm Member Since: 06 Jan 2015 Location: chorley Posts: 179 |
On the 3.6 the turbos can be done without taking the engine out it’s not the easiest job but possible ( we did one recently parked up on a mates drive ) they went only because the egr’s had failed |
18th Apr 2020 1:38pm |
thanks,could you give me an idea of how you went about the job,anything you would do again differently what sort of time it took etc |
18th Apr 2020 2:14pm |
the problem you will have is not knowing the damage to the rest of the engine.
18th Apr 2020 5:46pm |
definatly food for thought.many thanks |
18th Apr 2020 6:08pm |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
Find the used replacement engine cost, this will give you an idea,of risk |
18th Apr 2020 9:11pm |
