![]() | Home > Maintenance & Mods (L322) > DPF full 4.4 TDV8 2012 |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
Do a search on here but intake leaks is where you should start before driving it again. Check the 4 doughnut hoses under the engine cover first, check intercooler hoses, check intake manifold for leaks. Ideally a smoke test machine is needed to help find it. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35885
it can take up to 20 mins drive...basically you need to run it until its hot enough to burn off the soot ....surely there must be a pharmacy 20 mins away.. |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790
20 min blast up an autoroute of your choice. |
| SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 263
Any idea why it was smoking so much before the warning came on?
| Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1885
6 miles is nowhere near enough a clear out the DPF |
I appreciate that mikey
| dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450
This sounds a bit similar to what I have experienced with my own 2011 4.4 TDV8. I had some air intake leaks that were fixed by my local Indy, however just before lockdown the sudden plume of smoke came back and my DPF threw the amber followed by red warnings. I managed to clear the red and carried out a regent but haven’t been able to go any further due to the current restrictions. I’m hoping that once these are lifted I can carry out some more testing so will be interested to hear if you find anything in the meantime. You can read my latest issue in the link below.
Hi again
Anyone? |
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3285
several members have posted their versions of replacement pipes. do a search and you will see several options |
| jackie-o Member Since: 15 Jun 2018 Location: Sweden Posts: 226
partsnumber is 4 x LR056285 RR Vogue 4.4 TDV8 - 11
| GGX Member Since: 31 Jul 2013 Location: North Wales Posts: 61
I cleared by putting in sport mode and drive at 55mph for 20min on a duel carriage way, sport holding the gear down to it revs more generating more heat. |
Just an update
1. Do you have an IID tool or OBC reader? Your soot reading should be less than 28g as above that it cannot be force regenned by a dealer. It will have to be cleaned.
| All times are GMT |
