Home > Maintenance & Mods (L322) > Suspension Air Compressor
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Not sure if this is in the correct section.
Right. Last year we had the compressor overhauled (Wabco on a 2003 L322), basically our local mechanic fitted new O rings etc and the compressor was working fine.
Last week one of the front airbags failed and the RR spent a day or two with our mechanic. He fitted the new airbag but the compressor was struggling to lift the car.
He managed to source a replacement (Wabco) compressor from a breakers in Melksham and the car now is great! He said that the old compressor was only reaching 6 bar pressure where the replacement is up around 11 bar.
Now here is my question.
Is this old compressor worth anything?
Is it worth putting up on eBay as long as I stress that it may not be in full working order?
Or is it just scrap?
Any suggestions welcome!
I can put up some photos if necessary.
Post #550834 18th Apr 2020 5:46pm
pcourtney
tested and working ones go for £50 quid, but if its not working at 11 bar, then sell it for parts on ebay, you might get £20 quid for it
I recently refurbished mine with a kit from this lovely fella in Scotland £25, rather than take a chance on a second hand one for £50
https://www.bagpipingandy.com/compressor.html
Andy you tube video -
the same Wabco compressor is used in many other cars, so someone might buy it for spares
The repair kit will fit all car manufacturers using the same Wabco air suspension compressor including:
Range rover L322 and Discovery 2 and Jaguar XJ8
Mercedes E-Class and Mercedes S-Class (compressor removal guide)
BMW X5
Audi A8/Q7 and Audi Allroad
VW Touareg
Porsche Cayenne
Post #550845 18th Apr 2020 6:36pm
Guihan
United States 2007 Range Rover HSE 4.4 V8 Stornoway Grey
Wow...great info. I'll keep this in mind in case I ever need it. Thanks.
Post #550949 19th Apr 2020 11:19am
Biggles1957
Bagpiping Andy's kit is brilliant! And so ids the 'how to' video....
Post #551074 20th Apr 2020 10:06am
Dizzy Dee
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
+1 on Andy's kit, have just done mine last weekend. easy 10 minute job.
Post #551179 20th Apr 2020 9:50pm
p38arover
Australia
I was away for the past two weeks on holiday and had the dreaded air suspension inactive message come up. I cleared it with the GAP IID tool but it would recur. The error message was about not detecting a pressure change (I didn't note it exactly).
Luckily, unlike the P38A, the L322 doesn't drop to the bump stops when that happens so I was able to get the final 300+km home without issue.
Yesterday, I hunted out, amongst my spares, the bagpipingandy www.bagpipingandy.co.uk repair kit I bought back in July 2016 just in case I needed it (can you see the P38A ownership coming out in me?)
Replacing the piston ring was relatively easy. The cylinder bore didn't appear or feel worn but the old piston ring did look a bit sad. (I'll take a photo later.)
Here are a couple of pics which complement Andy's instructions:
Unclipping the wiring connector from the bodywork. Andy doesn't say how to do this but through a bit of experimenting I found one twisted the connector 45 degrees and it popped free of the mounting bracket. (Hmm, my fingernails look a bit grubby.)
Removing the plastic cable clamp - the instructions don't say how to do this. It just required slipping a screwdriver behind the two mounts and levering it off. The clamp is pushed onto two threaded studs.
Removing the temp sensor
If this bit is unclear, the temp sensor is retained by a clamp bolt accessible from the back of the frame.
The old piston ring before removal. I'll add another pic (after removal) later.
The car lifts much faster now, I'll see how it goes over the next few weeks. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #644265 29th Sep 2022 4:29am
pcourtney
my bagpipe overhaul is still going strong three years later - so as long as you get 10 to 11 bar, you will be fine Smile
Post #644487 1st Oct 2022 3:47pm
Googs
Australia
Good write-up p38arover, i did the same repair a few months ago coupled with a new to me (secondhand) center valve block and it's lifting great....i also got my kit from http://www.bagpipingandy.co.uk/ 2003 RR L322 4.4 ltr Auto Zambezi silver Custom paint
Post #644496 1st Oct 2022 5:16pm
karatzdi
Cyprus 2006 Range Rover Vogue Td6 Zambezi Silver
Hello . AM a new guy in this group. Got and L322 M/Y 06, which about a year ago was listing on one side (right hand side) if left unattended for some time. It was through Covid lockdwns I discovered this. So after all these lockdowns cease, I took it to my mechanic.
We made a plan and he recommended to me to overall the compressor, then replace of course the silicon bids in the dryer canister, then and we will see how it goes from there.
So I bought from the UK the overall kit for the compressor and the overall kit for the air dryer. I also bought the Valve Block O-ring repair kit.
When these arrived, I took them and the car to my mechanic. Same day he delivered the car back to me. Car was working fine, lifted a couple of times with no indication of overheating and no warnings whatsoever on the display. Let the car unattended as I was away for a couple of weeks. Came back car was listing again on the right hand side. Contacted the mechanic he said that we probably need to replace also the valve with the Part number RVH500050. I order it and it arrived in two days. Took the car back, and the mechanic delivered it back in 2 days.
Went to pick it up, 300m down the road "Suspension disabled" "Do not exceed 50KPH" messages on the display.
Ever since we get different messages like "Compressor overheat", "vehicle is lifting slowly" "suspension disabled" . Also there was a message for the RH rear height level sensor that the diags were not able to lets say "read" from.
I have read many good comments about the kit for the compressor overall. So I took the car to another mechanic. The second mechanic lowered and lifted the car 2 or 3 times consecutively and we got the same messages a s previously few lines up. He suggested complete compressor replacement...
So now am desperate. Is it the mechanics and they messed things up and they will not tell me the truth or the compressor overall went really bad, or is it something else. However out of all these, the car is not listing any more. Very Happy
What are your opinions and / or advises lets say ? Honestly I feel like getting another overall kit and this time do it my own just to make sure and isolate whether or not this is a compressor thing !
Post #645670 15th Oct 2022 9:16am
