![]() | Home > Maintenance & Mods (L322) > Front mudflaps drilling? |
| RRYorks Member Since: 13 Jan 2020 Location: Yorkshire Posts: 53
Sent PM |
| Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 701
I'm going to say yes. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
| jackie-o Member Since: 15 Jun 2018 Location: Sweden Posts: 226
Fox889 you would be correct. RRYorks was kind enough to send me a pdf.
| Anvil Member Since: 18 Jan 2019 Location: Dorset Posts: 147
Could I trouble you for a copy of that too? Please?
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35886
this is from our wiki,
Thanks Stan. I did it again.... made an assumption that as there was a PDF that it wouldn't be in the Wiki..... 3 strike rule? |
The simple answer is YES & NO! If a dealer fits them then yes they will drill the bodywork BUT! You don't need to drill the bodywork! The holes in the sides are for them that seriously use their RR's off road! The side bolts simply help you NOT to rip the things off!
@ CTC; thanks! Since mine are already fitted by a previous owner I´m going to guess they were drilled. Will have a look once car is back from garage.
Mine's an 06, so the wiki suits thanks J-O. I had some delivered the other day and I've fitted them, but they came with BMW 7-series fitting instructions for some reason..... Just wanted to make sure I did it correctly. -Turns out I did!
Jackie, yes they all fit in the same holes sir 👍 |
| All times are GMT |
