Home > Off Topic > What shed base on the lawn |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 509 |
Not for a garden room but for a shed I just removed the turf, put down weed suppressant and supported a wooden raft on breeze blocks.
20th Apr 2020 8:29pm |
It depends what you are putting on it. If it’s just a small shed based sour side room then a base of hardcore, the 2’ x 2’ x 2” slabs bedded on a sharp mix will do fine.
20th Apr 2020 8:35pm |
Couple of threads related from D3/D4
20th Apr 2020 8:38pm |
Big Boy R44ROV Member Since: 14 Nov 2011 Location: Ford Hill, Wirral. Not Merseyside Posts: 554 |
Depending on the quality and compaction of the soil it will be sitting on, dig down approx 600 deep x 450 square. Blind the bottom with about 150mm of 19mm blinding stone graded to dust. Tamp down and sprinkle with a touch of cement for a dry mix to bind. Sit Concrete building blocks 7.3N 440mmx215mm on the blinding and level. Space at 1.5m centres. Site your vertical wooden prop on that to secure the base ,backfill and away you go. Don't forget to treat the timber. (Blackjack ) Tony
20th Apr 2020 9:18pm |
Bradders Member Since: 03 Dec 2018 Location: Gods own country Posts: 417 |
Given its size and intended use I can't see why hardcore, sharp sand and concrete paving slabs won't do the job. Current: FF Westminster money pit
21st Apr 2020 9:39am |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
Don’t have enough information to form an opinion and comment.
21st Apr 2020 10:54am |
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 719 |
Cheers guys, will look into it more once it brightens up a little. Only downside of having the Mrs at home all day every damn day... keeps throwing stupid spur-of-the-moment ideas at me |
28th Apr 2020 6:43am |
