![]() | Home > Maintenance & Mods (L322) > 2011 battery connections |
| dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450
I can grab a photo for you tomorrow if no one responds before then |
| Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1102
https://www.fullfatrr.com/forum/topic43662...eplacement Current: 2011 FFRR Vogue SE 4.4 TDV8
| kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1364
Mines the same mate. I wondered the same as you. I used it for a fly lead for my charger. |
| nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690
take look here-
| dirtymonkey38 Member Since: 14 May 2017 Location: West Yorkshire Posts: 158
So this looks normal then? No nut required?
| kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386
Mine's like that. Annoying as I wanted to use it for my ctek too. I found a suitable bolt next to the battery though. 2010 4.4 TDV8 Vogue SE |
to me it looks like you missing this nut
Im still no clearer haha, so doesn't need a nut on it then?
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002
As per Nino’s post, aren’t you missing that nut then? 2011 Range Rover Vogue SE 4.4 TDV8
yeah looks that way, if anyone knows what size i need to replace the missing one? 2011 RR Autobiography 4.4 TDV8 |
I had a genuine Land Rover battery put on, warranty claim, by my main dealer and I can assure you there was no nut on that thread. Try moving the wire. It will be solid. It bolts on down the back I think from memory. |
| RRYorks Member Since: 13 Jan 2020 Location: Yorkshire Posts: 53
No nut as 'standard' I used it for the ctek, standard M6? nut |
| Bluegreygreen Rangie 2 Member Since: 27 Feb 2020 Location: Australia Posts: 77
No Nuts.... |
All sorted, disconnected my dashcam (thinkware F800 Pro) after fully charging the battery again and its still 100% charged after 24hrs. Might have to look into split charge systems and fit my old varta G14 battery in the boot. 2011 RR Autobiography 4.4 TDV8 |
| All times are GMT |
