Home > Wheels & Tyres > Locking wheel nut key code
Sester
United Kingdom 2014 Range Rover HSE SDV8 Santorini Black
How do I find out which locking wheel nut key I have ?
There’s various codes but which do I have ?
I was told there was a card with the code on in my pack but there isn’t ?
2014 RR
Thanks in advance 👍
Post #551569 24th Apr 2020 3:11pm
4434Morrison
United Kingdom 2012 Range Rover Vogue SE TDV8 Santorini Black
I had lost the locking wheel nut key on an earlier Range Rover - drove to the local dealer in Ashford, Kent. The parts chappie was able to determine the key number and was able to supply from stock - problem solved in minutes. 2012 4.4 TDV8 Vogue SE Current
2015 E220 with AMG Sport Pack - Currently driven by my son
2010 3.6 TDV8 Vogue - Written off by my son
Post #551572 24th Apr 2020 3:36pm
Ah the good old days when you could just drive to a dealer Laughing
Post #551578 24th Apr 2020 5:03pm
Baltic Blue
Or even better, drop Dan an email and it would magically arrive at your door in days Big Cry
Post #551580 24th Apr 2020 5:25pm
Sester
Thanks guys. The problem is the dealers are shut due to some sort of pandemic 🤔😒
I’m worried without out it something is gonna go wrong 🤦‍♂️
I’ve found some on internet but loads of codes and don’t know which mine is 🤦‍♂️🔫
Can I find it out somehow ?
Post #551581 24th Apr 2020 5:32pm
the letters a to z should be on the nut.. ... - .- -.
Post #551583 24th Apr 2020 5:47pm
Baltic Blue
Have you tried logging on to Topix ?
You will need your VIN, but all the car build details for a 2014 will be there.
Post #551586 24th Apr 2020 5:58pm
So have you lost yours ?
Are you sure it's not in the holder in the boot ?
Post #551587 24th Apr 2020 5:59pm
Sester
Stan thanks I’ll check if I can see it in the wheel !
Baltic blue, what’s topix ? Where is it please ?
Post #551588 24th Apr 2020 6:00pm
Open your boot - lift the spare wheel cover & have a look on the left side - under a carpet flap thingy
Post #551589 24th Apr 2020 6:03pm
Baltic Blue
Topix is the Jaguar Land Rover database where dealers record all the service details for your car, but it includes lots of other information.
Try Googling JLR Topix.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #551590 24th Apr 2020 6:20pm
Sester
Would you believe it Alistair was right I’ve found it !!!!
Thanks guys !
Post #551598 24th Apr 2020 7:12pm
You're not the first - I'm sure you won't be the last Rolling with laughter
Post #551599 24th Apr 2020 7:19pm
James W
Saudi Arabia 2017 Range Rover Autobiography SDV8 Siberian Silver
He certainly wasn't the last Rolling with laughter
This forum Bow down Bow down Bow down
I had the whole boot emptied, the jack out, everything! How did I not spot it there! FFRR SDV8 Autobiography
Post #656454 13th Feb 2023 12:45pm
