Home > Technical (L322) > Hose problem
oooMURPHooo
United Kingdom 2010 Range Rover Vogue SE TDV8 Buckingham Blue
Hose problem
Hi all, I have a 2010 RR TDV8 and it has issues. Not long after owning it it developed a power problem around 1500-2000 rpm. It would judder and lose power. I could push through it and it would pull OK. Also while there was a loss of power and accelerating there was a brief clatter/knocking (sorry its the only way I can describe the sound) a cloud of smoke and it would return to normal. I took it back to the garage I bought it from and got them to check it over under warranty. They fixed it and told me it was a split air pipe. I picked the car up and everything was fine. The same problem has returned 5 months later. Looking under the bonnet I can see the n/s intercooler pipe was the one they replaced so I have checked the o/s one and it is OK. My diesel knowledge is VERY poor so I wondered if there are anymore hoses that relate to the intercooler system I should check?
Many thanks,
Chris
Post #551592 24th Apr 2020 6:50pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Hi Chris, sometimes the splits can be hard to see without removing the hoses, also the genuine hoses tend to split fairly often so some replace them with silicone ones that will last a very long time Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #551604 24th Apr 2020 8:46pm
oooMURPHooo
I took both off yesterday to inspect the underneath, I did notice that the old one had a build up of soot around the hose where it connects back into the engine. Not sure if that points to anything. Thanks for the reply 👍
Post #551621 25th Apr 2020 8:59am
rjff
Hi Chis
If there is a build up of soot around the outside of the join/connection on a hose I think it indicates you may have a leak at that joint. That would lead to a possible reduction of boost to the engine. Look at all the hoses and joins carefully as Dolph says and perhaps follow his advice to change them for silicone.3.
Also if you use search you will find quite a bit about hoses and leaks. I'm assuming that your car is the 3.6TDV8 Cheers
Richard
Gap IIDBT
Post #551630 25th Apr 2020 10:38am
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Have a we look at my for sale post just bumped back to the top, if that fits you, make me a cheeky offer
Post #551632 25th Apr 2020 10:48am
