![]() | Home > Maintenance & Mods (L322) > Crazed/cloudy headlamp lenses |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 667 ![]() ![]() ![]() |
In the kit I had, if I remember, it started with 800 grit then 1500, 2000 & finished off with 3000. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 844 ![]() ![]() |
You dont need to sand them, g3 is ok but mcquires scratch remover is better on glass or plastic lenses
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3955 ![]() ![]() ![]() |
Ragingrover Member Since: 05 Oct 2019 Location: Malvern Posts: 152 ![]() ![]() ![]() |
There are kits available on ebay, Amazon etc. They do work very well but you need to be patient, following the process fully and not short cut or rush it. Its also a bit of a leap of faith first time ! lol |
Rapiscan Member Since: 28 Apr 2018 Location: North Lincolnshire Posts: 182 ![]() ![]() ![]() |
Thanks for the advice, wonder if a dual action polisher would, speed up the process? |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
Yes, you can use different grades of compound and then finally jewel polishing, clean with IPA then use a proper UV safe clear coat.
WB Member Since: 26 May 2016 Location: London Posts: 303 ![]() ![]() ![]() |
Yes a DA would definitely be handy |
