![]() | Home > Technical (L322) > No amber air bag light when ignition is on |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1197 ![]() ![]() ![]() |
dennij Member Since: 24 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
It is more than likely a wiring problem had similar check the squib on the steering column and also cable between the passenger airbag and the drivers they were my problems |
Finally got some time to look at this issue. Unbolted passenger seat to check all connections underneath, unplugged each one in turn and gave a good blast of air, some dust but nothing else so put seat back together. Carried out a hard reset and then cleared all faults with the IID. Air bag fault is no longer showing which is a good thing but still don’t see any air bag lights on the dash. No idea why but I guess at least the fault is no longer showing |
