Home > In Car Electronics (L322) > Rear seat entertainment wiring routes/daigrams |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1097 |
I'm guessing a bit but I think the cables are tied in the other looms too -- from the little I've done with mine (it does have RSE) I don't think it's a distinct overlay loom, seem more to be wrapped together.
28th Apr 2020 10:07am |
Garnerj Member Since: 07 Aug 2018 Location: Milton keynes Posts: 48 |
Thanks Bushy30, I was kinda hoping that may be the case as usually this would mean that some of the cabling is already n place in mine. I have had a quick look though and cant find any spare connection in the side of the boot where the DVD and RSE module would go, I know that the MOST loop cable would deal with the data for these and a simple loop addition would do that but it wouldnt help with the power etc. Im also keen to understand the route from there through to the seats and centre console etc.
28th Apr 2020 10:25am |
Yes indeed, let me know, I'll help if I can ! Current: 2011 FFRR Vogue SE 4.4 TDV8
28th Apr 2020 10:58am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3199 |
I don't know if it helps but on the 2006 - 2010 workshop manual if you search the PDF with "rear seat entertainment" it comes up with some information, including a schematic of component locations.
28th Apr 2020 11:01am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3692 |
Weegie,
28th Apr 2020 11:19am |
Thanks Mike. I had only seen the padlock against it. John
28th Apr 2020 11:41am |
https://www.fullfatrr.com/gallery/albums/u...tions..pdf
28th Apr 2020 11:43am |
Thanks Guys, the links given show the component location with some working as well which is what I had originally looked at. It was really helpful but don't actually show the cable routing locations unfortunately! |
28th Apr 2020 5:55pm |
Sorry, I was aware that it didn't show the routes -- but it does show the connections from unit to unit -- which will help identify the bits of loom I hope Current: 2011 FFRR Vogue SE 4.4 TDV8
29th Apr 2020 9:51am |
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 |
I did this in my wife’s old D3 many years ago. The technology is basically the same so you should find my write up from “back in the day” useful.
29th Apr 2020 6:38pm |
Cracking bit of work that Andy ! Current: 2011 FFRR Vogue SE 4.4 TDV8
29th Apr 2020 6:42pm |
Cheers Andy, that’s a real help. I had actually already found and read through your write up about 20 times. It’s actually what gave me the confidence to give it a go! I have a disco as well as my 2 fattys, did contemplate doing it in that but her indoors was not keen on having to get demoted to the disco! Plus I got the option of the parts for the tdv8 so that’s first on the list. I like a challenge but any little snippets are always welcome!
29th Apr 2020 8:28pm |
