Home > Technical (L322) > door
A.Pires
Portugal 2002 Range Rover Vogue Td6 Zambezi Silver
door
Hi all
On my 2002 L322 the system lock of the door oposite to the driver side which in my case is on the right side, don't open with the key fob. It closes but don't open. What can be the cause? Door actuator probably?
Cheers
Post #552490 3rd May 2020 12:54am
rjff
There was a thread on here about a cable rubbing causing damage in the door electrics where it passes through sleeving at the door to body area. It may have been a lock or window, regret cannot remember which. Take off the door card, clean all the electrical connectors you find and check they lock mechanism and cabling.
May be a start, hope it helps. Cheers
Richard
Gap IIDBT
Post #552525 3rd May 2020 12:50pm
