![]() | Home > Technical (L322) > Fitting a voltmeter into the dash |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35885
why dont you get one of those usb things with a voltage readout...saves cutting the dash.. ... - .- -.
| dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450
They also do one that plugs into the cigarette socket |
| Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1057
I have one of these it's a USB fast charger and has the charging voltage displayed just plugs into the cig lighter.
| ur20v Member Since: 19 Feb 2019 Location: None Posts: 634
Leave your gap iID tool plugged in and the volts show on the information display in the dash all the time 👍 |
| Gazcw Member Since: 11 Jan 2020 Location: Northampton Posts: 172
You could get a usb voltmeter and leave it plugged into the cubby hole or for £15 or so you can get an obd head up display and then have speed, temp and voltage options on you windscreen. 2011 4.4tdv8 Vogue
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
You can view the volts in the hidden menu area |
something like this ???
That's pretty much what I have in mine BUT mine also let's me play music from my phone via fm tithe car stereo, hence I dont feel the need to rip out the standard infotainment system. |
| p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1587
Remove the clock and fit it there. Ron B. VK2OTC
| Rapiscan Member Since: 28 Apr 2018 Location: North Lincolnshire Posts: 182
Hi, thanks for all the options offered, I don't have a usb port so the only option would be to have a cigar socket one but the only socket up front is, in the ashtray which I'd have to leave ajar with the thing sticking out, just doesn't seems elegant or tidy.. |
Think I'll give the flat surface mounted one off ebay a go for a fiver.. Ta folks. 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989
Mine mounted in a 2004 TD6.
| TJRL Member Since: 07 Sep 2019 Location: Reading Posts: 198
Looks good, I have couple of questions:
^^. Used a fuse that is permanently on, never had a problem with battery drain caused by it. Been on the car for about eight years to date. |
| All times are GMT |
