![]() | Home > Technical (L322) > HDC ISSUE |
| tj196443 Member Since: 08 Oct 2018 Location: Newcastle Posts: 190
Mine is a 3.6 so settings are probably different Richard, I'm sure it's a case of not being able to switch it on manually and will likely see if I can get to the switch button to see if there's a problem with the switch. I've checked the workshop manual and can't see anything about removing the terrain response panel that has the fixed rotary dial, there's a you tube video that shows the removal of the later type panel that has the rotary gear change so it's probably similar. |
Good tip Graeme, I made the assumption the fuse was ok for the HDC due to the HDC kicking in via the Terrain Response but if that fuse regulates the actual switch that may just be the issue and easier than stripping down the centre console. |
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2781
https://www.fullfatrr.com/gallery/albums/u...trol~0.pdf
Thanks for the info Graeme, just popped outside and low and behold the gear selector and sport mode lights are not lighting up ! Will check the fuse in the morning when it's light but likely fuse 21 is the problem so thanks for the heads up. |
If chasing a short circuit, note the other 2 uses of that fuse - rear climate control switch-pack and climate-controlled seat module. |
Morning all, checked fuses and none blown. Went to the trouble of checking all the fuses in the passenger compartment and none blown at all. Anyone know how to remove the rotary dial on the terrain response module ? Not sure if the rotary dial needs to be removed before you lift up the centre console or not. |
| rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198
Probably talking to the converted, (read talking drivel) but have you got the manual from the Wiki?
Hi Richard, managed to get the centre console off with no problems. Not difficult at all to be honest, just a case of pulling some trim off to access the screws. Took the plug off the Terrain Response module and all wires seem intact, was going to remove the actual module but don't think you would be able to dismantle the HDC button but might try that another day now I know how to get to it.
Photos of TFT afternoon removing and refitting the HDC wiring block
Hi Tom
Tom
Are the gear selector lights working? |
Hi Graeme, the gear selector panel does seem to dimly illuminate when the ignition is on but does not light up as the gears are selected which I assume is what is supposed to happen. Same when you slide it over into sport mode, the little panel does not light up. Checked all the fuses and all seem fine, I've stripped the console and check all the wires and all seems ok. Funnily enough I have an issue with the rear heated seats not working whereby the lights don't even come on and starting to think it may be a power feed that runs to the HDC switch through to the rear seat buttons. I tested the hdc in one of the special programmes and the system definitely worked just not through normal programme. Not an expert on electrics so probably would struggle to find the issue of it wasn't blatant such as a fuse or loose connector. |
| All times are GMT |
