![]() | Home > Maintenance & Mods (L322) > Possible Alternator failure |
| tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 343
Yep, sounds familiar. When the alternator seizes, it will stall the engine. Had this on my 4.4. It may have flat spotted the belt so I’d replace both if it is the alternator. |
| stenh02 Member Since: 30 Jan 2011 Location: Somewhere not warm Posts: 341
Thanks for the reply. Did you replace it yourself? And did you replace tensioners too?
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826
Download the workshop manual from WIKI, it's in there, not too bad a job, change the idlers if they feel rough or are noisy at all when you spin them, check the water pump, mine had play after the alternator seized so I changed it anyway... Have fun.. Pete
| alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6839
Sounds definitely like the alternator.
Got the old alternator out, very hard to spin so seems to be a duff bearing.
No, it should push all on it's own and put resistance on the belt... Pete
Ah, so is it more like a dampener? Both the top bracket and bottom assembly either side of the hydraulic cylinder pivot freely. When on the engine the top pulley wheel is at a fixed point but the assembly with the second wheel can rotate on that axis point.
TBH it was a few years ago I changed one... both the wheels were rough on mine, the damper does something to tension but exactly what I can't remember...!! Sorry.. Pete
Thanks Pete. The bearings on the pulleys seem fine. As long as it’s all meant to move freely when off the car and then physics makes it tension when the belts on that’s good enough for me. |
| Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2287
When I did mine I changed the lot as they had been there for 10yrs also changed the water pump same as Pete all preventative maintenance |
| All times are GMT |
