Home > Maintenance & Mods (L322) > LED front fogs
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
LED front fogs
Hi all
I stripped down my front fogs yesterday and cleaned the lenses as they were milky.
Since owning Sylvia I have uprated the headlights and sidelights so am now left with normal yellow light from the, now clean, front fogs.
Just trawling around on EBay at the vast choice of H11 LED bulbs and thought I would ask if anyone on the forum has upgraded?
Jim
Post #553011 7th May 2020 10:33am
Brian Considine
The optics of the reflectors/lens will not have been designed for LED's so by fitting them you will upset the beam pattern & loose the even "cut-off" you need for effective fog lights.
I tried that with my VW T5 & turned "adequate" fog lights into "useless except for DRL's". The light scatter at night was horrendous. 2003 Range Rover Vogue TD6
Post #553026 7th May 2020 11:37am
jim4244
Hmmmm, yes I know what you mean about the beam pattern.
I put a pair of LED’s in my main beam’s. Very bright, crisp, white light but the beam pattern was all over the place. I ended up taking them out and putting a set of Osram Night Breakers in.
I was hoping that as the fogs are a lot lower that the high/low beam units that the beam pattern would be better.
Jim
Post #553030 7th May 2020 12:01pm
jim4244
Has anyone tried the Osram LED car bulbs?
They are expensive but appear to have good reviews.
Jim
Post #553033 7th May 2020 12:19pm
in many years of driving i cant remember ever using the front fogs...
have you thought of changing them to drl's? ... - .- -.
Post #553043 7th May 2020 12:35pm
There are lots of aftermarket LED fog lamps available so, just buy a set of LED fog lamps and pop yours in the box on a shelf in the shed Thumbs Up
Post #553113 7th May 2020 10:30pm
DrRob
Have a look at Powerful UK Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #553129 8th May 2020 6:46am
