Home > Dealership & Service Feedback > West Hampshire recommendations - 2011 4.4tdv8
coopss
Hi all, finally picked up a ffrr - very happy.
I want to get a service and general check over done. Anyone recommend somewhere nearby?
I’m mid way between Salisbury, Andover and Winchester.
Cheers
Steve
Post #552645 4th May 2020 4:39pm
Just finds, no recommendations....
Candys in Fordingbridge
https://www.candys4x4.co.uk/
Inchape in Southampton (main dealer, but they say they are temporarily closed)
https://www.landrover.co.uk/retailers/inchcape-southampton.html
Hendy in Salisbury (main dealer, but they say they are temporarily closed)
https://www.hendy.co.uk/land-rover/dealers/wiltshire/salisbury/
Can offer competent indie (not LR specialist) - only other person I let touch my cars....
Richard Parker
Motomedic
Unit 13B Stonefield Park
Martins Lane
Chilbolton
Stockbridge
SO20 6BL
Tel: 01264 860600 .
Post #552647 4th May 2020 5:02pm
coopss
Many thanks, Richard/motormedic is just around the corner! Did you have your Range Rover serviced there?
Other place I found was pex5x5 in Abbotts Ann
Post #552687 4th May 2020 8:51pm
I tend to do all my own servicing, but Richard did do it once when I first got it, and some front suspension work for MOT. ( This was on my '02 L322 ).
He uses Keith Gott in Alton for parts (and probably advice....) .
Post #552692 4th May 2020 9:21pm
DrRob
Keith Gott in Alton
R&E in Salisbury
West 4x4 nr Bishops Waltham
Petersfield Garage Services (who I use). My mate is the LR specialist there. He works on my 2011
Rovertune in Reading (I use from time to time) 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
New Defender D300 90 on order so "Rory" will be going to a new home....!
Post #552699 4th May 2020 9:45pm
Clump
England 2010 Range Rover Vogue 4.4 V8 Bournville
I’ve used Alan Haighton in St Mary Bourne, competent mechanic with lots of RR experience, but not a specialist. 01264 738606.
Pex 5x5, who are just down the road from me, were disappointing in their communication. More Defender, judging by the piles of spares in their barn.
Fortunately I work in Basingstoke so not too hard to get to Rovertune. 2010 Bournville Vogue
Post #552851 5th May 2020 9:18pm
coopss
Cheers all - booked into Keith Gott for a service and check over next week Thumbs Up
Post #553093 7th May 2020 8:10pm
DrRob
Thumbs Up James Holland in the Service Dept there is a top guy. He used to work at Guava Guildford. 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #553095 7th May 2020 8:32pm
DrRob
PS Post lockdown etc then I’m more than happy to give it a once over for you Thumbs Up Not a mechanic but know what to look for having spent 18 months sorting mine out Thumbs Up
4th post down
https://www.fullfatrr.com/forum/topic44115...p;start=75
I had most of the usual oil leaks = cooler, pump and a turbo Big Cry 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #553096 7th May 2020 8:35pm
coopss
That would be great !
It’s had an engine, box, both turbos, alternator, starter, egr bits, belts, tensioners etc recently so hopefully the big ticket items done.
The ride is a bit choppy and feels a bit loose so looking forward to what Gott have to say!
Post #553109 7th May 2020 10:14pm
DrRob
Engine and box? Do you mean oil changes? 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #553128 8th May 2020 7:39am
coopss
Brand new gearbox and engine block (not at the same time)
Post #553137 8th May 2020 9:48am
DrRob
Crikey! That’s a lot of work and £££ Shocked 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #553299 9th May 2020 9:33pm
coopss
Great service at Keith Gott, did exactly as discussed, went above and beyond and charged exactly as agreed.
The list:
1. DPF regen
2. Service B
3. Lower arms
4. Inner steering rack joints
5. Alignment
6. Abs clip
7. CV gaitor
8. Axle oil seal
9. Hand brake hooks
10. 4x Pirelli Scorpions
Post #555162 24th May 2020 8:52pm
DrRob
Cool.
Why a DPF regen? 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #555208 25th May 2020 8:27am
