Home > Technical (L322) > Transfer case control module
Shawser1203
United Kingdom 2010 Range Rover HSE TDV8 Zermatt Silver
Does anyone know how to test the module off the car?
Post #553141 8th May 2020 10:24am
I would imagine it uses a canbus or some similar protocol to work so no I doubt you can test it off the car, fault codes should tell if it's working or not and they aren't repairable items as long as JLR are concerned so I doubt even they could help you out..!! Pete
Post #553145 8th May 2020 10:38am
Shawser1203
I got the fault code P279D-02 four wheel drive range signal circuit general signal failure.
Post #553147 8th May 2020 10:46am
Not up to speed with the later cars yet, you could try someone like http://www.bba-reman.com/gb/index.aspx if it is a common failure they maybe able to help... Thumbs Up Pete
Post #553153 8th May 2020 11:06am
GraemeS
Australia
I would get it tested in-situ using a diagnostic tool eg the IIDTool.
There can't be much wrong with it because it is a gateway on the canbus so if its electronics fail then all of the non-critical control units would have canbus communications faults.
Post #553154 8th May 2020 11:09am
Shawser1203
Just got another diagnostic done. 2 different codes. P0666 and P181D
Post #553158 8th May 2020 12:23pm
GraemeS
Australia
What is the diagnostic tool that is being used to read the codes? Important in the diagnosis is knowing which module posted the fault code.
P181D appears to relate to the TCCU calibration so perhaps a calibration is needed which might either fix the problem or reveal what is causing the original fault.
Post #553160 8th May 2020 12:59pm
Shawser1203
It was a snap on diagnostic tool. Is the calibration process easy to do?
Post #553167 8th May 2020 1:30pm
GraemeS
Australia
It requires a diagnostic tool that is programmed to issue the command to tell the control unit to calibrate the transfer case motor. The motor controls the range changing and the centre diff clutch pressure.
Post #553202 8th May 2020 9:37pm
