![]() | Home > Technical (L322) > Odd starting issue...l322 04/05 vogue lpg |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822 ![]() ![]() ![]() |
You say, won't start, what do you mean, it doesn't crank over, it cranks slow, it just clicks... it cranks at normal speed but won't fire...?? Pete
magu Member Since: 22 Sep 2014 Location: Burton on Trent Posts: 28 ![]() ![]() ![]() |
Hi Haylands
Prinz LPG will have no effect on starting, nothing has to "purge" that's with the old single point system...
No its not turning over and getting the click, disconnect battery leave it 8 hours reconnect and it starts...but it has to be left for the extended period. tried waiting up to an hour reconnecting fully charged battery and..click...i'm about ot go and try it again as its sat there 3 hours now...trouble is i have to go by bike as its presently stranded about a mile away outside the pharmacy i went ot collect my prescription from yesterday !...and its a |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1417 ![]() ![]() |
Are you sure the new battery is fully charged.
If the click is from under the bonnet then that is the solenoid of the starter clicking and the starter not engaging.. sounds like you need a new starter, when a motor is hot it will have more resistance, so yes it will work better when stone cold... |
Just gets better...so i managed to get it started and managed to get it home...now when i put the key in and turn to position 2 the rev counter jumps to show just over 2000 rpm and hovers around there...the engine is still unstarted at this point and i can hear something running in the vicinity of my feet on the drivers side unsure what this might be oh and to cap it all i get a oil pressure stop engine warning...before its started...which ecu is responsible for this witchcraft ? |
Sounds more like low battery voltage, have you checked it, is your charger working OK..? Pete
left it on charge overnight (new batt) took 3 attempts to get started and sounds like its struggling ot get fuel ,turned off to go lock the door....and click...same again...tried it again and managed to get it to start twice but rough idling,revs going up and down unaided,even attached fully charged old battery via jump leads in case ini9tial starting had drained new one..same..click!
